7th December 08, 03:24 PM
Sewing straight pleats
I haven't sewn but a couple of mono color kilts out of the eighteen I have done.
I was wandering how do you get a truly straight pleat with no vertical lines to follow? I have done it (but not very straight though).
Robert "the kilted" Lamb
"IF YOU CAN'T DO IT IN A KILT IT'S PROBABLY NOT WORTH DOING!"
KILT YOUR WAY TO EXCELLENCES
Clan Lamont Society of North America, Clan Scott SocietY,
Oregon Scottish Society, Northwest St. Andrews Society
7th December 08, 04:23 PM
Folding the fabric and ironing in the crease before you start to sew helps if you are careful to keep everything straight and flat.
Anne the Pleater
7th December 08, 04:52 PM
If you're talking about sewing a traditional knife pleated kilt, it's rare that the edge of a pleat actually follows a stripe, because pleats typically taper from hips to waist. So, pin the pleat at the hips and at the waist at the right size (I would *not* press first), pull the pleat straight and taut, and put in some more pins. And then be sure to keep the pleat under tension when you sew.
7th December 08, 05:43 PM
I have made a solid black kilt. I measured and marked each pleat at the top and at the selvage. I used the marks as the center of each pleat. You just need to make sure that your top and bottom mark are in line with each other.
8th December 08, 07:05 AM
Thanks for the help all.
Barb What you suggested is purty much what I do. I have a waist that is larger than my hips, so tapering is not a problem.
I have found in my kilt making, I never do any pressing until after I have sewn down all the pleats to 9ins.
So I guess I must be doing something correct.
8th December 08, 08:37 AM
Robert,
Are you asking about sewing a solid color Kilt or a Tartan Kilt?
And what sort of fabric please?
www.Freedomkilts.com
2nd Laird of Lochaber
8th December 08, 04:42 PM
With a solid colour kilt, without pressing in a crease I'd be lost.
When using a patterned fabric I find it easy to use the distance from a stripe as a guide, but on fabric with nothing to give an eyeline, no chance.
I made a start on a black kilt recently, but the light is too poor even with pressing in creases - I have set it aside until Spring. I will try a DPM one in desert camo colours so I can see what I am doing.
Anne the Pleater
8th December 08, 06:36 PM
I measure the pleat with a thin cardboard "jig" and steam iron the heck out of it and then use a "blind-hem foot" for the sewing machine to hold a straight line.
8th December 08, 06:59 PM
In self-coluor cotton denim, I have pressed first, then pulled and sewn.
In self-colour wool, I sew first, press later. (Basting stitches left in to aid in the alignment during the pressing) I also have made a cardboard jig to help me keep the pleats straight.
In tartan fabric, I always sew first, then press the pleats. ( made easy by the basting stitches that I left in.) again.
But then I am not a kiltmaker like Barb T, Steve Ashton, or Wally. I have only made about a dozen kilts for myself and family, using Barb T's book for procedure now. (Kilt quality improved)
Slainte
8th December 08, 08:12 PM
I have if I press before I sew I find if I press a little off I find if very hard to unpress the pleat. So sew first and I can make the ajustments as I sew along, then I press. This goes with plaid or mono color.
By Splinty in forum Kilt Advice
Last Post: 7th September 08, 12:10 PM
By ardchoille in forum General Kilt Talk
Last Post: 27th August 08, 02:46 PM
By Moosedog in forum DIY Showroom
Last Post: 1st March 07, 02:24 PM
By gilmore in forum DIY Showroom
Last Post: 26th January 07, 06:23 AM
Last Post: 23rd June 05, 08:39 AM
