  #11
Old 11-06-2009, 07:40 AM
Bugbear's Avatar
O, I understand now.
I'm still trying to figure out the fine details on the flaps.
Hope it all goes well.
__________________
  #12
Old 11-06-2009, 10:21 AM
Hothir Ethelnor's Avatar
I'll let you know how I make my flaps when I get to those and then you can judge from the pictures how it turned out.
I hope it does too.
I am making my second version today from a cheap fabric I picked up at an upholstry place. It is heavy and has a felted texture similar to a heavy coat wool, and it holds a nice crease when ironed, so I hope it will give me a good idea of how the wool suiting fabric will lay. This version will be taken to completion with sleeves, lining, collar and flaps.
  #13
Old 11-06-2009, 10:47 AM
RB51's Avatar
I don't sew things worth a hoot but I do admire craftmanship in others, and salute you for undertaking such a project. Looking forward to seeing the final product.
Laurie
__________________
The secret of happiness is freedom,
and the secret of freedom, courage
Thucydides
  #14
Old 11-06-2009, 12:51 PM
Bugbear's Avatar
Someone, a while back, was saying those flaps, tashes I think..., are on the doublet to resemble armor.
I've been trying to read through my book on Medieval armor to find out if there were flaps on Knight's armor that might be a little like the doublet flaps. I'm not exactly sure what I'm looking for.
__________________
  #15
Old 11-06-2009, 05:12 PM
Alan H's Avatar
Father of The X-Kilt
OK, this is some serious work. Good on ye.
  #16
Old 11-06-2009, 09:15 PM
Quote:
Originally Posted by Hothir Ethelnor View Post
The pattern did not specify pads and I don't think they were used in the original garment so in my fitting and testing of the mockup I noted to extend the shoulder parts of the pattern to accommodate that.
(now to go finish fitting the collar and adjusting the front "lapel"...)
The doublet isn't a terribly tailored garment, but one from a good tailor, made for especially for the wearer, would certainly have padding in the low shoulder. It's also going to have a lot clever iron-work to stretch the bits that need stretching, and shrink the bits that need shrinking.
One of the problems with working from the _practical cutter_ stuff is that you're supposed to know how to do these things, so they don't tell you. And final fitting would be done with the very nearly finished garment, on the owner, if they could manage.
  #17
Old 11-10-2009, 08:26 PM
Dixiecat's Avatar
au contraire. I would imagine that it didn't specify padding because it wasn't a book about fitting, but a book about military patterns.
The heavy fabric for your second fitting is a very good idea. Don't forget the padding especially in the shoulders, even if your shoulders are equal. Not all padding is for fitting, shoulder padding in heavy coats is to help support and shape the fabric to help distribute the weight. The heavier the fabric and the longer the coat, the more support it needs on and off the body.
Please don't take any of our advice as criticism. I think you're doing an awesome job.
  #18
Old 11-10-2009, 08:54 PM
I'm not about to get offended.
I will pad the shoulders.
I hope to get back to this project this week I am working on some other stuff as well (wedding video, sporran, maple leaf kilt pleated to the sett...) It all kinda adds up.
I'll have another update with pictures of the skirts/flaps/pockets or whatever the term for them really is, tomorrow.
  #19
Old 11-10-2009, 10:59 PM
fluter's Avatar
Great work! I'm all eyes. Dixiecat, thanks for the tips and observations...
P.S. nice tartan, too.
__________________
  #20
Old 11-10-2009, 11:40 PM
Heming's Avatar
The side back seams (princess seams) are areas like that. In addition to stay stitching the straight parts, try shrinking the curve on the side piece. Sew two rows of basting (I do this by machine) through one layer only just outside the seam line and another just inside. Tighten the threads on the wrong side to shrink the seam line slightlywithout wrinkling or puckering. Press well to set and then sew up your garment. Makes a big difference.
Shoulder pads would be made from large pieces of thin fleece or heavy felt, layered and shaped, and would go down onto your shoulder blade in the back and down to your chest in the front.
But I'd use modern ones, set slightly into the sleeves. Make sure to get the "male evening coat" version. And I would use some light to medium fusible interfacing in the fronts (unless you have experience with canvas interfacing).
Keep up the good work!
__________________
Vin gardu pro la sciuroj!
Tags
diy, doublet, jacket, pattern, sheriffmuir
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Sheriffmuir Jacket A_Hay! How to Accessorize your Kilt 32 02-21-2009 01:40 AM
Startin' from scratch... airforcedave72 DIY Showroom 11 03-30-2008 09:04 AM
UK scratch and dent irishrob Contemporarily made Kilts and How to Wear Them. 6 10-02-2006 07:02 PM
Albannach at Sheriffmuir - 12 November 2005 Mike1 Show us your pics 4 05-24-2006 08:50 AM
Battle of Sheriffmuir Commemoration Mike1 Miscellaneous Forum 1 11-12-2005 05:55 PM
X Marks Sponsors
