Results 1 to 10 of 16
    Sort of kilt with sleeves
    Winter is here, and I need a dressing gown. This is the plan. I have made 'Bog Coats' before - the method is very old, but they did not have pleats.
    Take a piece of fabric - in my case 60 inches wide. Cut off a piece/pieces from the raw edges to make two edging bands for the front and neck and a belt.
    One selvaged edge is folded over and will form the sleeves and upper body.
    Cut vertically up the centre front of the folded over piece and a few inches along the fold each side for the neck - it will need to be shaped later.
    Cut horisontally in from the raw edges, for the sleeve and any cuff or turn back. Fold the lower part in to make the fronts of the garment.
    Sew in pleats to narrow the back and upper part of the garment. Attach the top selvage to the fronts. It might not be a straight seam, slope it so the lower front falls straight, not pulled up.
    Sew the sleeve seams. Neaten the raw edges. Shape the fronts like a kimono, but make a rounded neck as it is warmer than the kimono style.
    Attach edging bands, joining them centre back neck.
    Make a belt and loops.
    It seems like a good idea.
    Photos and snags to follow.
    6th December 06
    Michigan
    Looking forward to the photos!
    24th November 06
    Oregon
    Me too. I haven't had enough coffee yet to be able to visualize it...
    Moosedog
    14th December 05
    Coeur d Alene, ID
    Sounds great - how about a rough pattern sketch along with the photos... Please?
    Phil in Idaho
    8th November 05
    Northglenn, Colorado, USA
    Sounds interesting. I, too, can not visualize it so hope pics and/or drawings come soon.
    15th July 07
    California
    I'm on my second pot of coffee, I've answered all the important e-mails, and I've read this over three times.
    What gets in my mind is like a serape with sleeves and pleats?
    Your description is probably smack on, but I can't fully visualize it yet. Curiously waiting for the flix.
    sew down pleats between marks to narrow back to about shoulder width and form thick warm area
    _______l______________l_______
    l l l fold to form top of front and sleeves
    l l l
    l _l_ l neck/shoulder level,
    l l
    l l
    l_______ _______l < cut here to form sleeves
    l l
    l l approx waist level
    l l
    l l
    l l
    l l
    l l
    l l
    l l
    l l
    l_______l_____________l________ l
    fold sides in to form fronts
    If you take a piece of paper and make the three cuts, then fold sides in and top down you should see how it works.
    Last edited by Pleater; 19th November 07 at 01:25 PM. Reason: Drat - it is perfect in edit, not when saved
    24th November 06
    Oregon
    Pleater,
    Thanks! I still have no idea what you are making... but in the process of trying to figure it out using a paper scrap I came up with the solution to another design problem I've been grappling with.
    Just goes to show the power of the pleats...
    Moosedog
    Just 'bumping' this so I can find it when I get the photos in place - as I am not the most technologically gifted I need to plan ahead to smooth the way.
    22nd November 07
    Desert SW USA
    This is very interesting! But it kind of sounds like a pleated leine, but I'm not sure. That's OK, I won't tell anyone... Good luck, hope it turns out well.
  1. DFW Kilt Night (sort of)
    By RowdyRed in forum Kilt Nights
    Last Post: 8th November 07, 01:46 PM
  2. I'm back (sort of)
    By Nick in forum Miscellaneous Forum
    Last Post: 22nd August 06, 06:49 AM
  3. Found a kilt shop...well...sort off.
    By Robin in forum General Kilt Talk
    Last Post: 9th December 05, 09:06 AM
  4. New Kilt (sort of)
    By Calico Jack in forum Traditionally Made Kilts and How To Wear Them
    Last Post: 14th December 04, 04:50 PM
  5. a Kilt related joke(sort of)
    By Raphael in forum General Kilt Talk
    Last Post: 30th June 04, 11:43 AM
