23rd December 08, 09:45 AM
sword blanks from leaf springs
This is an interesting article for those that might be interested.
http://www.livesteelarmor.com/how/warsword.html
Don't ever get yourself caught cross-ways in a ditch with them there elephant people. ~CJC
I say we lift off and nuke the site from orbit. It's the only way to be sure ~Warrant Officer E. Ripley
23rd December 08, 11:22 AM
As an historic re-enactor, I will have to try that. I wonder how leaf spring steel compares to carbon steel for actual strength.
23rd December 08, 11:49 AM
Great article. I've bookmarked it and will give it a try when the weather warms up
This should explain carbon steel-
Low Carbon: contains about .05-.30% carbon and of the three, because of the relative low cost of production, it is used extensively. Some sources of low carbon scrap are car bodies, some types of rebar, old nails, bolts, panels on railroad cars, railroad spikes, some types of angle iron, rolled pipe, some types of wire, nails, straps, hinges, tanks, drums, etc. It is manufactured in rolled bars, and the most common ones are round, flat or square bars of ¼ - 1". It is NOT temperable but may be forge welded.
Medium Carbon: contains roughly .30-.60% carbon. It is a harder material (harder to work and harder to find), and may be tempered. It is the most available temperable scrap metal. Some sources are springs, axles, torsion bars, gearshift bars, shock absorber bars, and, in general, anything that must stand up to a higher degree of stress and strain. It will not bend easily like mild steel. It is also used where tempering is required (e.g., auto/truck axles, auto/rail car springs, leaf springs, steering columns).
High Carbon: contains roughly .60-1.5% carbon, and usually has an alloy present. It is much harder than medium carbon, but is available in scrap sometimes as old pneumatic drill bits, old bulldozer blades, milling cutters, metal saws, cutting dies, threading dies, and files.
23rd December 08, 12:49 PM
Nepalese kamis have been making khukuris out of leaf springs (often from old Mercedes) for many decades. It's good steel.
Jay
Clan Rose-Constant and True
23rd December 08, 01:00 PM
The Thais use leaf springs for their large knives (similar to machetes). They were much admired, but hard to come by.
Every man thinks meanly of himself for not having been a soldier.
~Samuel Johnson
People don't like to be meddled with.
~River Tam
23rd December 08, 01:12 PM
There is nothing wrong with the steel. However, there is a LOT of bad advice in that article. Beating on old leaf springs, COLD, is asking for trouble, and mostly just a lot of unnecessary work for you (and really bad for your hearing). The claim that no small outfit can do as well as a big auto corporation for heat treating is simply nonsense. You can do it that way, but it is by no means the best way.
I have no doubt that the author is sincere, but he is also confused about a great many things regarding steel and metallurgy.
I do make a living, making high performance swords, btw.
Nothing personal, just be aware that it is not the best information out there concerning the making of a sword. I highly recommend www.dfoggknives.com and www.britishblades.com/home/ as good sources on the web.
23rd December 08, 03:47 PM
I have heard of making knives (and sghians) out of recycled leaf springs...interesting.
Best
AA
23rd December 08, 04:10 PM
In general, springs are made from steels that are quite suitable for making blades. Almost any spring will make a decent blade if heat treated appropriately. As springs, they are a bit soft for supreme edge holding, though they are "hard enough" to make a halfway decent knife without changing the hardness by heat treating.
Beating a cold spring flat, from it's arched condition is very difficult, and silly, and not good for the steel's microstructural condition.
23rd December 08, 04:22 PM
how about a sharpening steel?
Would an old sharpening steel be worth recycling? I'm looking at a Henckel steel, at least 20 years old, which has lost its --- whatever makes it hone, I suppose the surface pattern has worn down over the years.
23rd December 08, 06:12 PM
I noticed the bad advice as well. One of my hobbies is blacksmithing, and as a result I notice any "bad advice". I've made several knives and trying a sword is on my list of things to try.
I've bookmarked those 2 sites you mentioned.
By Jerry in forum DIY Showroom
Last Post: 12th March 08, 06:03 AM
Last Post: 10th October 07, 09:43 PM
By Sheep In Wolf's Clothing in forum DIY Showroom
Last Post: 31st August 07, 05:22 PM
By cloves in forum DIY Showroom
Last Post: 24th May 07, 09:13 PM
By prairieson in forum DIY Showroom
Last Post: 27th April 07, 09:11 PM
