Old 02-03-2010, 12:38 PM
Has not logged in for 1 year
Tapering Question
I am making an X-kilt, albeit with some modifications. Basically, I had a little cloth lying around, and I'm turning it into a kilt.
There wasn't enough material to go all the way around as the x-kilt article describes, so I'm making it with a more "traditional" apron that goes all the way around to the point of each hip.
This is my first attempt at an X-Kilt, and I'm having some issues with tapering from fell to waist .
As I understand the directions, I'm supposed to ensure that the edges of the pleats remain touching each other from fell to waist, and do the tapering by pulling the inner part of the box pleats towards each other, centering them in the middle of the pleats.
The problem that I'm running into is that the edge of the upper portion of the pleats is distorting. basically, as I pull the inner section of each box towards another one, the edge of the outer pleat is distorting getting narrower at the top.
Now, this seems logical, but is this what is supposed to happen?
Advice for completing this project would be welcome.
-Loki
Old 02-05-2010, 07:18 PM
Farlander's Avatar
I think you are fine. The goal is that the kilt should taper so that it is narrower at the top. As the directions say, use plenty of pins, and "[p]inning these tapers is a PAIN, but grin and bear it and do your best".
Keep at it! It will be be fine...
__________________
Michael the Farlander
Loch Sloy!
Old 02-05-2010, 07:57 PM
Thanks!
I got it done. I ended up layering the pleats over one another on both the outside and the inside. Worked like a charm! I was just nervous about messing up another project.
Thank you!
-Loki
P.S. I will be posting pictures of the completed denim kilt sometime soon.
Old 02-06-2010, 09:08 PM
Eleazar's Avatar
Sounds like you got it figured out. Looking forward to the picts. I haven't done one in denim yet.
__________________
Eleazar
Mark H. Morrison
CHG WIT-ISBD
Old 02-06-2010, 09:32 PM
Denim works great!
I haven't posted pics yet (I'm still figuring out Photobucket), but denim is great material.
Advantages:
-easy to crease
-sews fairly easily (at least in the 6-8 oz weight)
-denim thread almost disappears!
-durable
-looks good with almost anything (it's a "jeans" kilt!)
-pretty cheap at Wal-Mart
Disadvantages:
-wrinkly. Tends to show when you sit down.
-careful of the stretch varieties!
Old 02-07-2010, 12:06 PM
bear@bearkilts.com's Avatar
Making a kilt is much the same as wearing a kilt. There is some anxiety when you try new things but once tried, you find your fears were needless.
Making a kilt is actually easier because you can always undo mistakes and start over.
__________________
Kilts are garments, not costumes!
The MacBitseach Himself!
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Tapering Tartan Kilt SergeantBort DIY Showroom 5 11-06-2009 10:20 AM
Tapering the fell kd0afk DIY Showroom 9 07-13-2009 01:34 PM
Knife-pleat tapering info Phicong DIY Showroom 19 09-14-2007 10:10 AM
A tapering nightmare. Erisianmonkey DIY Showroom 8 03-28-2007 03:18 PM
X Marks Sponsors
