Results 1 to 10 of 11
    15th January 08
    *610* PA
    thought I'd try my hand with rabbit fur
    Well as luck would have it, my sister brought over her childhood rabbit fur coat for any one of my two youngest daughters to wear. Neither of them wanted to wear it...lol. It's old but in nice shape...however real fur is not their thing...so I was thinking - rather than throw it out I'd cut off an arm and see how a sporran might look.
    Here's the "before":
    Outside:
    Inside:
    Almost done:
    inside "hanger" reinforcement piece:
    Inside shot:
    I removed the gold liner and that revealed that the skins were sewn to a canvas backing/base cloth.
    This is the shoulder of the coat arm and you can see that I simply tucked under the 'outer/top' part of the shoulder of the sleeve to make the bottom.
    I made two flap covers of the same leather - about 12oz each and stitched them together around a short length of fur. These are sealed inside with ModPodge to make it stiff and glued together in the center of the flap.
    My entire hand fits inside the pouch, to just above my wrist. With my hand all the way open, I can barely touch the left and right sides. It's about 8" wide at the top and almost 9" tall.
    As you can see, I'm not quite done trimming the edge of it (the flap) and I will look around Celtic Fest this weekend for a nice god Triquetra or Celtic Cross jewelry piece to mount directly in the center. I may burnish the edges instead of wrapping them with other leather and resewing...or I may use matching waxed sinew to cross-whip stitch the edge...not sure what I want to do yet.
    Any thoughts?
    And Shephards we shall be for thee my Lord for thee; Power hath descended forth from thy hands; That our feet may swiftly carry out thy commands; So we shall flow a river forth to thee, And teeming with souls shall it ever be. In nomine Patri, et fili, et spiritus sancti.
    14th May 08
    Slovenia
    Recycling is my goal, too. It's amaizing what can you do from "non-usable" things.
    Keep on working!
    16th September 08
    Charleston SC
    Nice Work
    I have been waiting to see who would post a rabbit piece 1st. i like what you have done with the sleeve. I cant wait to see the finish project. I have a rabbit pelt in my shop thats just dying to be made in to a sporran.
    Thanks
    Whisky for the gentlemen that like it. And for the gentlemen that don't like it - Whisky.~Major Jock Sinclair-Tunes of Glory
    31st August 08
    New Mexico
    Hey, very strange but this morning I was thinking of a rabbit fur sporran as well. I was thinking of checking e-bay for pelts but ill bet the local good-will has some coats for sale. looks great! A large silver Celtic design and 3 rabbits feet with silver mounts and chain would look great. OK maybe the rabbit feet are over the top...nah
    Many is a word that only leaves you guessing.
    15th January 08
    *610* PA
    Quote Originally Posted by Mipi View Post
    Keep on working!
    Thanks. I couldn't bring myself to just 'throw it out' and thought about it for a while and then this popped into my head. It didn't take long to make it at all...just cut the pattern for the flap leather and sew it on.
    Quote Originally Posted by Kilted Rogue View Post
    Thanks
    It's a bit tricky to work with because the nature of the fur makes it "slide" around while you are working with it. Use safety pins or little spring clamps to hold the skins in place while you work on it...or small touches of glue. Use a curved glover's needle to make it easier to work with. I used waxed (imitation) sinew with the main line split into three separate strands and only used one of those strands to actually do the sewing. The waxed nature of this sinew tends to grab the guard hairs of the pelt and drag then through the hole as you draw the sinew so I might suggest an unwaxed nylon thread to make yours a bit easier.
    Quote Originally Posted by Eric Peterson View Post
    Our Local Celtic Fest started around 1700 hrs friday eve and goes until Sunday night. I was down for a short time, looking for something to adorn the flap with and think I found it...
    It's a silver pewter Triquetra necklace on the round leather thong cord. The pendant is about 1.5" at its longest length and suspended upside down by each half of the black cord. I'm fairly certain I can rig it to the flap in a most pleasing manner, suspended by that black cord. I want to look around a bit more on Sat and Sun just in case I can find something I like more.
    As to the tassels, I thought about that too...perhaps I'll curl up some hair into tubes - or I have some whitetail antler that I can make "button"-looking things to hang in front.
    I think with the rest of the coat, I'll try to make an original kind of Brogue/boot-like moc. I'm not even sure on how I want to attack that and don't even know if I put the hair on the inside or out. I have to research that a bit more but I'm fairly certain the hair goes on the inside..and then what weight leather to use for the soles....lol.
    31st August 08
    New Mexico
    Cant wait to see the finished pictures.
    15th January 08
    *610* PA
    As promised, I got a decorative piece for the flap and installed it...
    24th March 08
    the Highlands of Central Oregon
    Quote Originally Posted by druid View Post
    Isn't that called a "triskellion?" Where did you get it, if you don't mind me asking?
    15th January 08
    *610* PA
    No...the Triskelion is this: http://en.wikipedia.org/wiki/Triskelion
    the Triquetra is this: http://en.wikipedia.org/wiki/Triquetra
    I boughtt this at a little shop at the Celtic Festival this weekend here - www.alittleirishtoo.com - they have some very nice items
    Here are some more pics I just uploaded too:
    and some pics from the festival...This was before I added the Triquetra to the sporran....
    The family around the Kilted Spongebob dude:
    Me and Jessica (19)
    Elizabeth (12) - these are the 2 coming to OK DDay with me. This 12yr old is the one playing and the 19yr old will be camera girl...lol...
    Victoria (9)
    Vickie not liking the Haggis and mom pretty much agreeing with her:
    Jess and her BF:
    Trying to be gangster in her new hat:
    Vickie being a goof:
    16th September 08
    Charleston SC
    Thumbs up
    Thanks for the Rabbit Tips.
    ill put them to good use..
    (rabbit tips.. sound like an interesting culinary delight. Rabbit Tips with pearl onions and pea's..mmmm now i am getting hungery)
  1. Rabbit sporran and belt
    Last Post: 2nd July 08, 01:12 AM
  2. Rabbit Fur
    By Skweres in forum DIY Showroom
    Last Post: 9th March 07, 08:26 AM
  3. New Kilt & Rabbit Fur Sporran
    Last Post: 5th January 07, 09:47 AM
  4. White Rabbit Sporran Et Al
    By mrpharr in forum How to Accessorize your Kilt
    Last Post: 3rd July 06, 04:18 AM
  5. Must have been one strange rabbit...
    By Sherry in forum How to Accessorize your Kilt
    Last Post: 29th March 06, 01:29 PM
