+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Two sgian dubh
    8th May 11
    Vancouver BC Canada
    Re: Two sgian dubh
    Very nice job.
    I have a couple of blades I will try the mustard trick on.
    Thank you and a great instructional post.
    Lang may your lum reek and a wee mouse never leaves your cupboard with a tear in its eye.
    3rd January 08
    Illinois, USA
    Re: Two sgian dubh
    Wow, great job! Those blades look like an old antique blade, and I mean that in a good way.
    Member Order of the Dandelion
    29th November 11
    Kalispell, MT
    Re: Two sgian dubh
    Quote Originally Posted by sevenoaks View Post
    Thanks! I love to build things. I'm always more intrigued with the process than with the finished product...I guess I'm posting pics in the way I'd want to read a thread!
    Quote Originally Posted by Standard View Post
    Thank you!
    Sheaths will be a hybrid belt/hose sheath. The belt loops will be to the sides of the sheath so I can wear it on my belt, and will lay flat under my hose.
    Rather than two separate sheaths for each knife, I'd prefer to have the knife live in a single sheath--and have them "wear" together.
    Stay tuned! I've got some more I'm working on. I really want to build some with either bone/antler handles, or wood with bone/antler details.
    1/8 Scots, kiltmaker, boater, wheeler!
    29th November 11
    Kalispell, MT
    Re: Two sgian dubh
    These blades need sheaths!
    My brother likely won't be wearing his in his socks, and I may wear mine on a belt with my p@Nt$, or in my hose, so I made a pair of hybrid sheaths.
    First, I make a pattern.
    Trace each blade. Sketch ~1/8" outside this profile for the stitching, and another 1/8" outside that for the edge of the leather:
    Roll the knife on its edge and trace the outside of the handle. This gives me enough leather for the top piece of the sheath:
    Sketch in the slot the belt passes through, plus 1/8" for stitching, and 1/8" to the edge of the leather. This is the pattern. For simplicity's sake, I'll leave it a big triangle and cut it down later.
    Cut the leather:
    Soak it:
    29th November 11
    Kalispell, MT
    Re: Two sgian dubh
    Lay the lower wet leather on a towel.
    Cover with plastic wrap:
    Knives in place:
    More plastic wrap to protect the knife from the wet leather. Like I'm worried about the antiquing!
    Top pieces, roughly pressed into shape:
    I want the back piece to be nearly flat against my leg.
    I want the top piece to hold the bolster area of the knife securely--this is where all the shaping happens.
    I cover the leather with soft, open-celled foam, then a piece of plywood, then clamp the whole thing to the countertop and leave it for the day. A lot of the moisture in the leather soaks into the foam and into the towel. Remove the foam and towel a day later and let the leather air dry.
    29th November 11
    Kalispell, MT
    Re: Two sgian dubh
    Finally, time to stitch.
    After the leather is dry, I tooled in my "MT4Runner" logo.
    Drilled 1/16" holes with a cordless drill and stitched with waxed nylon thread with a tapestry needle.
    The stitching is more even on top than on the bottom--I didn't hold my drill perfectly straight, so some of the back holes wandered.
    Cut the belt loops to shape:
    Cut them out and then re-wet the leather at the stitching. I used the bottom of a pub glass to press the stitching down into the leather so it lays flatter. Also burnished all the edges
    Finished with leather dye:
    26th March 08
    Atlanta, GA
    Re: Two sgian dubh
    Arg... Can't see the last three images.
  8. #18
    14th May 08
    Slovenia
    Re: Two sgian dubh
    Thanks for many ideas and detailed working process.
    Well done!
+ Reply to Thread
  1. Sgian Dubh - Sgian Don't - Sgian Dongle
    By Chas in forum DIY Showroom
    Last Post: 25th August 09, 05:04 AM
  2. New Sgian dubh & Sgian Brew and a very public thanks
  3. Sgian dubhs (dubh bebh dubh, new)
  4. Sgian Dubh How To
    Last Post: 20th September 06, 02:54 PM
  5. Sgian Dubh just won on E Bay
    By highlandcelt in forum How to Accessorize your Kilt
    Last Post: 11th September 06, 08:37 AM
