  #11
Old 03-05-2010, 05:40 PM
svc40bt's Avatar
Quote:
Originally Posted by Paul View Post
They look great!
Do you plan to sell them, or any other sgians?
No plans to sell them, though I will probably make a couple more at some point. Right now they are my only sgians.
  #12
Old 03-05-2010, 05:54 PM
svc40bt's Avatar
Quote:
Originally Posted by Old Hippie View Post
Sharp lookin'!
That's an interesting handle for the pattern-welded blade ("rainwater" innit?). For the base of the crown, you might want to do a little scrimshaw since it's a daywear sgian. Otherwise I'd say the founding for a largish jewel of some sort would always be snagging on something.
The antler was not large and had a significant curve, so I cut it short. I considered putting in a brass spacer then more antler, but wanted to blend out to the width of the blade. The brass seemed like it would work better. By the way carbide end mills cut both brass and antler like butter.
I had thought of a scrimshaw. Have to look into how to do it. Also thought of a thin cabochon with a brass solid wall setting. I could probably make one with the milling machine if I was carefull. My other thought was some sort of button or concho. Still thinking on it.
Anyone have any theories on a way to increase the pattern contrast on the blade?
  #13
Old 03-05-2010, 06:03 PM
svc40bt's Avatar
Quote:
Originally Posted by ShaunMaxwell View Post
Very nice! How would you rank the quality of the blades? I've always wondered, as they're pretty inexpensive...
Thanks for sharing your work.
First let me say my blade sharpening skills are marginal.
That said the pattern weld blade seems to have taken a decent edge and seems likely to hold it.
The stainless blade was nicely polished, until I gouged it up being impatient, but I haven't been able to put much of an edge on it.
  #14
Old 05-16-2010, 02:43 PM
svc40bt's Avatar
Made a sheath for the antler one. Saturated it with CLP to keep the blade from rusting. Turned it a nice medium brown. Decided on a brass cap, as my test scrimshaw did not turn out so well. May get it engraved eventually. Here are a couple more pictures, plus one for Jock showing the antler crown against a flat surface.
Sheath and brass cap
Brass cap.
Sgian on a flat surface with crown hanging slightly down.
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
New Sgians at STM M. A. C. Newsome How to Accessorize your Kilt 11 03-23-2009 08:30 AM
my new sgians Dirk Skene How to Accessorize your Kilt 16 11-07-2008 06:57 AM
Some new sgians soon! Raptor DIY Showroom 1 06-26-2007 11:37 PM
Add Your Unique Sgians Fearnest How to Accessorize your Kilt 30 03-21-2007 10:06 PM
Thoughts on Sgians Dubh Ialtog How to Accessorize your Kilt 39 12-05-2006 08:14 PM
X Marks Sponsors
