Tutorials & How-To's This is where you can find some fine tutorials and how-to's from our members.
Closed Tutorial
Tutorial Tools Search this Tutorial Display Modes
Another DYI Flashes Tutorial
The Wizard of BC
Published by Steve Ashton
02-17-2010
I remember that there was quite a discussion on making flashes at Kilt Kamp.
I, of course, do things slightly different from Barb but basically the same. Not wanting to hijack her flashes tutorial I thought I'd show you how I do them.
We all do things a little different and so should you. Experiment, have fun.
Here are some shots of some matching flashes for a Kilt in the Nova Scotia Tartan.
I use a fusable non-roll waistband interfacing. It is exactly 1 1/4" wide so it gives a good clean fold. Laying it directly on the fabric allows me to layout on the diagonal easily. Lay it out, then iron it down.
The interfacing I use is stiffer than the what Barb uses and I think I'm going to try some of hers.
here's a shot folding over the fabric on the back side. I then use stitch witchery fusable to hold it down.
Another shot of the folds on the back side.
One of the different things I use is black fusable wiastband interfacing for the back side. This is known as "Jiffy Waistband" and is perforated in the middle to make it fold easy. I just cut or rip it down the middle and use one half. I think if gives a good looking clean appearance to the back.
I then use the corner of a drafting triangle to cut the notches. I do the cut with an Olfa circular cutter and finish them with scissors. Then a touch of Fray check to seal it up.
Then sew down the tops for the elastic.
A little trick I do is to sew a small bartack at the top and bottom of the elastic loop. It helps keep the flashes straight and together.
The finished product.
__________________
www.FreedomKilts.com
"CRY FREEDOM! and let slip the legs of woe."
Tutorial Tools
Closed Tutorial
X Marks Advertisers
Search this Tutorial:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Tutorial Tutorial Starter Category Comments Last Post
A Kilt tutorial fortcollinsjerry Kilt Advice 5 09-22-2009 07:49 AM
Posting Photos - Tutorial BEEDEE Forum News 0 09-14-2009 09:09 AM
Another DYI Flashes Tutorial The Wizard of BC DIY Showroom 8 06-16-2008 08:41 AM
style question - tartan flashes, solid flashes or no flashes? Moose McLennan How to Accessorize your Kilt 21 06-01-2006 07:43 AM
X Marks Sponsors
Tutorial powered by GARS 2.1.9 ©2005-2006
