+ Reply to Thread
Results 1 to 8 of 8
Thread: 440Hz pipes
    2nd February 09
    Garrettsville, Ohio
    440Hz pipes
    So I bought a set of Husk cane reeds a while back. They tune right at the hempline, just that tuning is 440Hz instead of the usual high 470s.
    Normally, I'd just push the drones down and tune up to the chanter.
    But I also happen to have a spare chanter. I've been messing with it, trying to get it down as close as possible to a "true" A. The drones sound very rich and mellow at this pitch, I have absolutely no idea what the chanter will sound like after I'm done with it.
    Anyone else tried getting down to 440 without drone reed extenders and purpose built chanters? Am I crazy? Wait... don't answer that one.
    I'll post a sound file if I get it going right in the next few days.
    I wish I believed in reincarnation. Where's Charles Martel when you need him?
    5th November 08
    Marion, NC
    I've not tried it, but I hope the rest of the world will join you in your tempering of the chanter. It would make playing with other instruments (such as church organs) much easier.
    --dbh
    31st March 08
    London Ont Canada
    Re: 440Hz pipes
    Ive never tried to go down to 440.. Christ! I taught an air cadet band last year and tried to tune them as low as possible in a little competion to hide all their blowing issues that I just couldn't beat out of them. And i tell yeah. I had a hard time getting them much lower then 470!
    A friend of mine has a 440 chanter that he bought to play with organs and other instruments. But I don't know anyone who has modified a 480 ish chanter to 440.. Excuse my ingnorance, but how would you even do it?? tape the lower parts of the holes and carve the tops?? Extend the reed up??? How??
    2nd February 09
    Garrettsville, Ohio
    Re: 440Hz pipes
    Spent a few hours messing around with it today. Here's my results so far.
    The chanter in question is a Gael 474, the reed an Abbedour medium. Drone reeds are Husk cane.
    The drones are perfect pitch right at the hempline, pushing them down about an inch and a half gets them to 478, normal pitch.
    I wrapped TONS of hemp around the reed an seated it out quite a bit until the high A was right about 440, give or take a few hertz. I've threaded the reed seat, so adjustment isn't too much of a problem. Semed a tad unstable, so I didn't fine tune it just yet. Good thing. The low A was somewhere in the ballpark, nothing a little tape couldn't fix. The enitire right hand was passable, showed promise of being able to be tweaked a bit. Then I clamped down my right hand and let fly with an E. Jumpin' Jehosophat! Who let the dying cow in my house!?
    I'm not really willing to carve up the chanter, so maybe my experimentation is at an end for now. I'm off to Dunsire forums to glean more info about reed choices for these chanters. I just used what I normally play in my Dunbar Elite.
    31st March 08
    London Ont Canada
    Re: 440Hz pipes
    Thats the trouble isn't it?? Getting drones where you want isn't to difficult. And getting low A down low is also not to bad but the top hand is gonna bew the tricky bit.. You should see if you can find a junker of a chanter, something you can carve up.. Cause to be honest I think you're gonna have to carve the top holes..
    Good luck Id love to hear how it goes..
    6th November 08
    Re: 440Hz pipes
    My instructor needed a 440 chanter for a gig. Starting with a 466 chanter, eventually got to 440, but it was a lot of effort and probably didn't sound as good as a 440 chanter would have.
    But stick wires up the chanter, like guitar strings. They'll lower your pitch some.
    Re: 440Hz pipes
    I should mention that pipers often get into terminology issues when playing with "normal" musicians, in the matter of pitch vs key.
    The chanters which pipers call "466 chanters" are pitched in A=440, but play in the key of B flat.
    I know this sounds like an oxymoron, but for example clarinets can be bought in the key of B flat, pitched either to A=440 or A=442, and clarinets can be bought in the key of A, pitched either to A=440 or A=442.
    (Highland pipers would call these four clarinets 466, 469, 440, and 442 respectively, which "normal" musicians would find strange.)
    So in "normal" musical terms, the chanter that pipers call a "466 chanter" is in the key of B flat, in the pitch of A=440.
    The chanter pipers call a "480 chanter" is likewise in the key of B flat, but in the pitch of A=453.
    The difference arises because "normal" musicians use A as the reference note, while pipers use whatever the so-called "low a" happens to be as the reference note (usually somewhere around B flat).
    So if you're playing along with a pipe organ, playing Amazing Grace or Highland Cathedral, use a so-called 466 chanter. If the organ is in tune to A=440, you'll be in tune if you're at 466, and those tunes will come out in the key of E flat Major.
    Normal music pitch name = piper's pitch name
    440 = 466
    442 = 469
    445 = 472
    448 = 474
    450 = 477
    453 = 480
    455 = 483
    I have this chart taped onto the back of all my electronic tuners and it's saved much time and trouble over the years.
    HIghland pipes in the key of A, that is, chanter and drones sounding at 440 cycles, probably never existed in the old days. Old chanters are around halfway between A and Bb, in the neighborhood of 455 cycles.
    Carried away by the madness of fight, the English knight charged straight into the Spanish array. Here and there tossed the white plume of the English helmet, rising and falling like the foam upon a wave, until at last it had sunk from view, and another brave man had turned from war to peace.
    5th November 08
    Marion, NC
    Re: 440Hz pipes
    I'm a trombone player. Do I count as a "normal" musician?
    In concert band settings, we tune to Bb, which drives the oboe players crazy.
    --dbh
+ Reply to Thread
  1. Replies: 0
    Last Post: 10th February 10, 03:21 PM
  2. Should buy used pipes?
    By mouse 1 in forum General Celtic Music Talk
    Last Post: 28th December 09, 07:19 AM
  3. Need help with pipes
    By WarPreist in forum Celtic Musicians
    Last Post: 23rd April 08, 06:17 AM
  4. Big day with the pipes!
    By Kilted Taper in forum Miscellaneous Forum
    Last Post: 30th January 06, 01:45 PM
