Tartans & Heraldry (temporary only) All the threads in this forum are being moved to other forums.
Old 12-18-2007, 12:56 PM
keltic falcon's Avatar
tartan design
hi folks, and merry xmas from scotland.
here is a question (i hope its not dumb) i am thinking of designing a tartan for my self - there is a tartan that i can use but its not called the falconer tartan any more but its called the keith tartan,
Q- do you think it would be ok to call the tartan Mac Falconer -even though the name does not exist.
__________________
Och i the noo
Old 12-18-2007, 01:01 PM
davedove's Avatar
Retired Forum Advocate
It would seem to me that you could call a tartan anything you want, although it probably shouldn't be the same as another tartan name, to avoid confusion. If you look through the Scottish Tartans Authority though, you can see that doesn't stop some people.
__________________
Lose something valuable to you and don't know who can help?
Call the Retrieval Team at 1-***-GETRBAK and we'll get it back for you.
Old 12-18-2007, 01:17 PM
TheKiltedWonder's Avatar
Would you be naming it Mac Falconer in order to distinguish it from the tartan previously known as Prince, errr ... Falconer?
If so why not name it Falconer of Motherwell, since you took the trouble of desiging it. Or is there a location that the Falconers are associated with that you could use.
I'm sure there's no rule against using Mac Falconer, I was just tossing out other possibilities.
__________________
#9 fan of http://www.poisoneddwarf.com/
ויתהלך חנוח את–האלהים ואיננו כי–לקח אתו אלהים
Old 12-18-2007, 01:38 PM
TheKiltedWonder - cheers for ur responce , i may use falconer of motherwell, i just thought i would ask and get various opinions on it.
__________________
Och i the noo
Old 12-18-2007, 01:48 PM
Galician's Avatar
Holiday greetings to you too!
Have you seen the sites which help in designing tartans? There are several posts which give links to them.
Do you have any photos of yourself and your birds?
Old 12-18-2007, 01:52 PM
Galician - sadly i dont work with birds.
__________________
Och i the noo
Old 12-18-2007, 06:23 PM
Nick the DSM's Avatar
sure why not? i would do similar stuff if i could.
__________________
Gillmore of Clan Morrison
Old 12-18-2007, 06:27 PM
ChattanCat's Avatar
Call it anything you want. It is your design.
__________________
and Professor
Old 12-18-2007, 07:18 PM
M. A. C. Newsome's Avatar
Owner - New House Highland
Contributing Kilt Historian
Here's some free advice.
First, if you were to design such a tartan, I wouldn't name it "MacFalconer" because that is a name that does not exist. If the intent is to design a tartan for the Falconer family, then it should be called Falconer. There is no such family as MacFalconer.
Secondly, there already is a Falconer tartan. It's the same as the Keith, Austin, and Marshall tartan. The fact that the tartan shares more than one name does not make it any less legitimate. (There are many examples of shared named tartans: Hunter/Russel/Galbraith/Mitchell, Black Watch/Campbell/Htg. Grant/Htg. Munro, Campbell of Cawdor/Argyll district, Grant/Drummond, Drummond of Strathallen/Ogilvie of Airlie, Kidd/MacPherson, etc.)
In this case, the Keith/Marshall tartan was adopted by the Falconers when the Lord Falconer took over the lands of the Keiths, Earls Marischal, in the early 1800s. So the connection is quite legitimate.
There is also a newer tartan called Falconer of Labhdal that was designed in 2005, and based upon the Falconer/Keith tartan. It has two blue lines on the green field, rather than one.
In short, there already seems to be an established Falconer tartan, which is readily available (most all tartan shops will have the Keith/Austin/Marshall tartan). Creating a new design for the Falconer tartan would seem to be reinventing the wheel. That, plus it would also seem that there is a titled head of the Falconer family that might have a thing or two to say about it!
Now, if you wanted to design your own personal family tartan for your own use and give it a name that would not imply general use (such as "the Bob Falconer tartan" or "Falconer of Motherwell") then have at it. But it seems to be the best bet would simply be to use the established tartan already available.
__________________
Matthew A. C. Newsome, GTS
Tags
design, tartan
X Marks Advertisers
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
design your own tartan info phil h General Kilt Talk 3 09-15-2007 07:05 AM
Design your own tartan Mark Keeney The Tartan Place 11 09-15-2006 12:08 PM
A tartan design for Harley davidson THISLPT Contemporarily made Kilts and How to Wear Them. 10 04-17-2006 11:30 AM
What makes a good tartan design tomcherv General Kilt Talk 5 09-30-2005 09:46 AM
X Marks Sponsors
