Results 1 to 10 of 26
Thread: kilt pin
    15th December 10
    Alberta, Canada
    kilt pin
    What ideas are out there to keep the kilt pin from coming unfastend/unclasped?
    lr
    30th September 08
    Cypress, Texas
    As RiverKilt and others on this forum have said: "Run the pin through a bit of wide rubber band on the backside of the apron. The few times they come unpinned they at least are not going to slip away and be lost. Simple and effective."
    If the pin is a blanket type pin, make sure you have the fastening end pointed downward, so that if it comes unfastened, it's less likely to fall off your kilt.
    At least that's what the people on the forum more knowledgeable than myself advise!
    Texas Hill Country
    Shaun pretty much gave the two best pieces of advice that I was going to say.
    I've never had a kilt pin come unfastened, and I would think it would be pretty hard for that to happen. But the rubber band trick ought to solve it if it does.
    5th November 08
    Marion, NC
    You could squeeze the clasp shut with a pair of pliers, but that permanently affixes the pin to your kilt. Go with Ron's rubber band trick.
    --dbh
    3rd January 08
    Illinois, USA
    +1.
    I often use a horse blanket pin (large looking safety pin) as a kilt pin and always make cure to apply it with the point downward.
    Member Order of the Dandelion
    I stole the rubber band idea from someone else, guessing its been around a long time. Some folks also run the back side pin through a small pencil eraser.
    Kilt pins DO come unpinned. Even had one come undone while I was seated in a car - the back pin was sticking up vertical and fortunately I noticed it just before I was going to rest my hand on my leg which would have skewered my hand.
    But, a piece of rubber band, or small pencil erasor run through the pin will keep you from losing your kilt pin when it does come unclasped.
    And beware kilt pin addiction. Ham advised one kilt pin per kilt to save wear and tear from repeated poking.
    PhotoBucket Album
    15th December 10
    Alberta, Canada
    Yes, this is helpful. I had the same thing happen in the car too. Pin sticking straight up. Nearly impaled my hand on it. The elastic band and pencil eraser are great tricks. I am relatively new to the board and realize that my questions are old hat to some of you guys. Thanks for patience. I like the idea of one pin per kilt. I saw a kilt that was quite damaged by the pins coming and going. Good advice.
    lr
    5th August 08
    Lancashire, England
    Kilt pin addiction? Yes... I'm having therapy for that.
    Best Regards John
    5th November 07
    French Alps, Europe
    Yes, the right thing to do.
    Best,
    Robert
    Robert Amyot
    23rd May 06
    Yes, I first read that one on here back in 2008, and recently shared it in another thread. It does work (& for the "safety pin" style of kilt pin too!)
    T. E. ("TERRY") HOLMES
    proud descendant of the McReynolds/MacRanalds of Ulster & Keppoch, Somerled & Robert the Bruce.
