5th January 12, 11:43 AM
#11
Re: cadagh and waistcoat planning
 Originally Posted by MT4Runner
Great project!
How about making the hose the circumference of your heel. Instead of a slit along your Achilles tendon, simply place a fold there--and still use the snap.
Less drafty in your cold climate, and the upper fold of fabric would hide the snap head.
Or..same idea, but use a hidden zipper?
Hmmm. So just make regular cadadh, put them on, and the sort of pleat up the excess and install snaps in the right spots to take the slack out?
I think it would work. It might work very well. On my ankle I would still have almost twice as much cloth as I needed, so pretty deep folded in hidden bits.
Also, the snaps would be through a single layer of cloth so that unsnapped the cadadh could open far enough at the ankle to let the heel back out. Maybe a bit of reinforcement cloth between the snap halves on the inside of the cadadh?
If someone has a pair they choose to try it on I would be glad to see pics.
5th January 12, 12:31 PM
#12
This is what a strip of clear elastic along the seam in the problem area would do with less bulk at any one spot. It would allow you to get the fit tighter than it is now, but still not too tight to put your heel through.
Clear elastic is used sometimes in ladies blouses from the shoulders to hook around the hanger so that the garment doesn't sag when hung up. Usually one just cuts them off when you purchase the garment. Mark out the area that you'd like to 'gather' in, cut a piece of elastic approx. 1/3 shorter than the area you marked out (plus finger holds!) and stretch out the elastic between the marked seam ends and zigzag in place. Don't make the elastic too short or you'll end up with a nice gather look at the achilles.
5th January 12, 12:43 PM
#13
Duh. Yeah, "a pleat". That word skipped my brain, but is perfectly clear to everyone reading it on this forum.
You'd have 3 layers at most, instead of two, but no gap or draft.
Another idea would be a pleat on either side, with the snaps on either side of your achilles tendon. You'd be pressing on the side of your tendon to snap, but while wearing, they'd be "floating" in that hollow and not rubbing your skin. They'd look a bit like a pair of spats or gaiters?
Exactly.
Reinforcement would be a very good idea.
Now I'm inspired to try this.
1/8 Scots, kiltmaker, boater, wheeler!
By wingedferret in forum General Kilt Talk
Last Post: 31st August 11, 02:47 PM
Last Post: 14th December 09, 09:06 PM
By Bugbear in forum Kilt Advice
Last Post: 4th October 08, 07:47 PM
By ardchoille in forum Highland Games and Celtic Event Discussion
Last Post: 2nd April 08, 12:09 AM
By Big Mikey in forum Miscellaneous Forum
Last Post: 17th March 07, 07:25 AM
