Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    28th April 17
    PA
    They can be tied quite loose so as not to cut off circulation and still stay in place to hold your hose up.
    I am a fan of circulation.
  2. #22
    16th May 08
    forgotten
    I don't think it is a matter of getting the garters tight as much as having a garter with some 'give' for when you move and walk. This is why I like knit garters. They can be tied quite loose so as not to cut off circulation and still stay in place to hold your hose up.
    Yes, you are right
  3. #23
    16th May 08
    forgotten
    For those that are knitting needle impaired you could use one of the sock looms that are available. Sock Looms have smaller pegs and are closer together than the larger looms. This allows for smaller stitches and a tighter knit. They are smaller than the looms show earlier and could easily be taken with you if you want to knit in public. In the United States these are available in most big box craft stores.
    https://www.amazon.com/Boye-8700000-...SIN=B00B7HDIZ4
    If you see abbreviations, initials or acronyms you do not know the Xmarks FAQ section on abbreviations may help.
    www.xmarksthescot.com/forum/faq.php?faq=xmarks_faq#faq_faq_abbr
  4. The Following User Says 'Aye' to Friday For This Useful Post:
  5. #24
    16th May 08
    forgotten
    This is another method that might work called stick weaving.
    <em>
  6. #25
    24th January 17
    Ellan Vannin
    Just a thought but a different approach you could take to making a different style of self tie garters might be to pleat together woollen strands in a similar way to the way women pleat their hair or like Scouts pleating lanyards from leather shoe laces - it depends how big & complex you wanted to make it? I guess 5he more threads the longer it would take and the more complex it would be, but you would produce a wider garter?
