Results 1 to 10 of 10
    19th July 11
    London
    Thickness leather?
    I want to have a go at making a leather kilt. What thickness leather should I use? and type?
    thanks
    25th January 04
    Stratford, Ontario
    Re: Thickness leather?
    There are a number of things to consider;
    Will you be hand stitching or machine stitching? If by machine, what is the thickest material can you currently sew with it? Factor in the number of pleats and waistband....have a good supply of needles on hand
    What style of kilt? traditional, utility, Roman. Depending on the style will determine the end weight of the kilt, which shall determine what weight of leather and how much you will be required to use. As for the kind, the sky's the limit, ostrich, moose, lamb, cow, bear, in the end it's up to you and what you're comfortable with working.
    Good luck
    19th July 11
    London
    I have an industrial machine with teflon feet available so sewing the leather shouldn't be too much of an issue. I was thinking of going for a 6yard knife pleat semi traditional.
    25th January 04
    Stratford, Ontario
    Quote Originally Posted by Emmet View Post
    If it's not a walking foot machine, light weight leather will be your best bet 1-1.5 oz. even with a teflon foot you will run into some challenges with the waistband and the layers of the pleats. For kilts I have found this to be on the light side, wrinkles easy, and doesn't give a good swish.
    19th July 11
    London
    And one more question, In your opinion regardless of sewing machine and technique what weight leather do you feel makes into the nicest kilt?
    25th January 04
    Stratford, Ontario
    I find 2-2.25 oz gives me the best results. (I'm one of the best leather kiltmakers in the world, so I speak from experience)
    Good luck with your project
    Robert
    14th August 11
    Houston, TX
    Having never made a leather kilt I can't say exactly.
    But 5oz leather can be used for "working" chaps.
    2-3 oz for chaps and upholstery
    Garment leather is 1.5-2 oz.
    You might look at lamb and pig skin as alternatives to cow.
    Please excuse the spelling errors. My IPhone is "helping" me.
    19th July 11
    London
    Quote Originally Posted by Mikewood View Post
    How about http://www.walterreginald.com/products.php?cat=12
    see the printed pigskin section
    24th September 04
    Emmet, I fixed your link for you.
    Forum Owner
    3rd October 11
    I have never sewn a kilt, but I've worked in leather quite a bit. I would recommend a lambskin garment weight leather, as it would be lightweight and comfortable. When wet it can be folded and when dry it will stay that way.
    Best, Tom
  1. Leather Jackets with Leather Kilts
    Last Post: 22nd March 11, 09:34 AM
  2. Leather Questions (Tandy/Leather Factory)
    By Cat in forum DIY Showroom
    Last Post: 23rd February 08, 01:40 PM
  3. Tartan thickness or weight
    By creativeaccents in forum General Kilt Talk
    Last Post: 20th November 07, 05:45 AM
  4. Leather
    By Jewddha in forum Miscellaneous Forum
    Last Post: 3rd January 06, 03:38 PM
  5. UK Leather
    Last Post: 25th August 05, 12:50 PM
