Results 1 to 4 of 4
    19th September 09
    New England, USA
    Tweed jacket with center split back conversion
    Hey all so I got a tweed jacket with a split in the center of the back. Is there a way to convert this to a kilt jacket? What should I do with the split?
    Let YOUR utterance be always with graciousness, seasoned with salt, so as to know how you ought to give an answer to each one.
    Colossians 4:6
    29th April 07
    Columbia, SC USA
    Quote Originally Posted by Cowher View Post
    Try it without a vent---just pin it up or cut to the target length (plus hem allowance), and pin the vent together. See how it hangs. There's less need at the shorter length.
    If it's full-cut, as most US jackets are, then you can probably taper the side seams enough to create side vents---assuming the seam is in the right place.
    Model it for us, and you'll get more opinions than you need.
    Spartanburg, SC
    I had a jacket cut down for kilt wear, and it was vent-less to begin with. Fluter is right, you really don't need a vent. Even if the jacket is cut full (mine was tapered) and you have it tapered on the side seams, you probably won't need to have vents.
    25th January 11
    My tweed conversion was ventless to start with too... I had to remove the buttons on the sleeves and sew those closed though, im guessing the back would be similar...
    You might want to look at a little tailoring of the jacket for shape though... I found the fit a little odd without the full drape of the fabric and nipped it about 3/4 of an inch on the back seam since the lining was out anyway...
    I would have to say that although 2 vents isnt uncommon on a kilt jacket, and they have been around since at least 1935 based on one of the jackets you can see in the 39 steps, they do look a little funny to me since theyre so short...
  1. Thanks ChattanCat for Tweed Jacket Conversion
    By Spartan in forum General Kilt Talk
    Last Post: 26th April 09, 08:18 PM
  2. Tweed Jacket Conversion
    By Packhound in forum DIY Showroom
    Last Post: 21st September 08, 09:41 PM
  3. Tweed Jacket Conversion Question
    By Captain Karrot in forum DIY Showroom
    Last Post: 20th December 07, 02:23 PM
  4. Tweed Jacket conversion
    By Fedgunner in forum DIY Showroom
    Last Post: 11th November 07, 07:42 AM
  5. Tweed jacket conversion - starting point
    By Avonlea22 in forum DIY Showroom
    Last Post: 19th June 07, 10:32 AM
