19th August 11, 10:11 AM
Weight of Tartan - Swatch
I received a swatch for some inexpensive 100% wool tartan material in Black Stewart tartan. The swatch is very soft--almost like lambswool. I measured the set, and I believe it's about 3 1/4", and fairly square, if my guess is correct. My question is, how much does a yard weigh, approximately? Is this 13 oz material? If it's not, how much material would I need to make a different garment, such as a waistcoat? I'm what you'd call a medium-build person, slightly shorter than average.
19th August 11, 10:57 AM
To make a waistcoat/vest, you'll need about two yards of solid-colored 45" wide fabric, if you plan to make the back from the same fabric as the front. If you're wanting to amke a tartan vest, with the tartan cut on the bias, it will eat up more fabric. I'd say 3 yards should do it, with a good bit of scrap left over.
I can't help you on the weight of the fabric. You might be able to ask the company you got it from.
--dbh
19th August 11, 12:19 PM
Thanks for the advice on the waistcoat. The company I bought the fabric from--an online cloth retailer, not a mill--did not know the weight of the fabric. Obviously, it's not heavy. Perhaps I shall have to use the postal scale and do some arithmetic.
19th August 11, 01:39 PM
If it's soft and woolly it's probably about 10oz
19th August 11, 01:43 PM
10 oz it is, then.
That's what it must be then, because it's soft and wooly. FYI: this fabric can be found for $19/60" wide yard at Renaissance Fabrics. It'd make great scarves.
20th August 11, 03:33 AM
The weight is per yard. If you have 10 oz material, and you have a yard long piece of fabric 54" wide it will weight 10 oz. Heavy weight 16 oz fabric will weigh a pound (16 oz) per yard.
By Maclachlan in forum Kilt Advice
Last Post: 14th October 10, 11:57 PM
By Bugbear in forum How to Accessorize your Kilt
Last Post: 30th March 09, 10:30 PM
By Robertson in forum Traditionally Made Kilts and How To Wear Them
Last Post: 11th October 08, 11:07 AM
By Kilted in Maine in forum General Kilt Talk
Last Post: 7th June 08, 12:49 PM
By creativeaccents in forum General Kilt Talk
Last Post: 20th November 07, 05:45 AM
