Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    22nd November 07
    Desert SW USA
    Using pinking in that way is a very interesting aproach... I have seen the soft, thin interfacing for hems on jackets. I'm guessing that is what you are talking about.
    14th August 07
    Halifax, NS
    Pinking edges of seams and interfacings is an old sewing trick. The 'broken' edge leaves no real line that can show on the right side as a ridge when pressed.
    The soft interfacing that you've seen in jackets may be a bit too thick to use with this tartan. There are thinner and softer interfacings available.
    As an addendum to my method, make sure that the interfacing is also a non-woven to prevent raveling of the interfacing edge.
    22nd November 07
    Desert SW USA
    Oh, I have seen the edge of the actual fabric on hems and seam allowances pinked, I just thought it was an un raveling issue. Pinking the interfacing, which is what you are talking about, is a neat trick. The interfacing I'm thinking of is usually folded by a third along the lingth, but I get the idea that it needs to be very thin.
    Thanks for bringing it up, DC.
  1. The Tale of the Wayward Traveller
    By The Wizard of BC in forum General Kilt Talk
    Last Post: 5th August 07, 06:14 AM
  2. A Tale of Two Dads
    Last Post: 19th June 07, 01:49 PM
  3. Tale of the Kilted Flyer
    By cessna152towser in forum General Kilt Talk
    Last Post: 10th December 06, 07:42 AM
  4. Now the tale can be told
    By NancyMan in forum General Kilt Talk
    Last Post: 15th February 06, 01:38 PM
