Results 1 to 1 of 1
    24th September 04
    15 Post(s)
    Another DYI Flashes Tutorial
    I remember that there was quite a discussion on making flashes at Kilt Kamp.
    I, of course, do things slightly different from Barb but basically the same. Not wanting to hijack her flashes tutorial I thought I'd show you how I do them.
    We all do things a little different and so should you. Experiment, have fun.
    Here are some shots of some matching flashes for a Kilt in the Nova Scotia Tartan.
    I use a fusable non-roll waistband interfacing. It is exactly 1 1/4" wide so it gives a good clean fold. Laying it directly on the fabric allows me to layout on the diagonal easily. Lay it out, then iron it down.
    The interfacing I use is stiffer than the what Barb uses and I think I'm going to try some of hers.
    here's a shot folding over the fabric on the back side. I then use stitch witchery fusable to hold it down.
    Another shot of the folds on the back side.
    One of the different things I use is black fusable wiastband interfacing for the back side. This is known as "Jiffy Waistband" and is perforated in the middle to make it fold easy. I just cut or rip it down the middle and use one half. I think if gives a good looking clean appearance to the back.
    I then use the corner of a drafting triangle to cut the notches. I do the cut with an Olfa circular cutter and finish them with scissors. Then a touch of Fray check to seal it up.
    Then sew down the tops for the elastic.
    A little trick I do is to sew a small bartack at the top and bottom of the elastic loop. It helps keep the flashes straight and together.
    The finished product.
    __________________
    www.FreedomKilts.com
    "CRY FREEDOM! and let slip the legs of woe."
  1. A Kilt tutorial
    By fortcollinsjerry in forum Kilt Advice
    Last Post: 22nd September 09, 06:49 AM
  2. Posting Photos - Tutorial
    By BEEDEE in forum Forum News
    Last Post: 14th September 09, 08:09 AM
  3. Another DYI Flashes Tutorial
    By The Wizard of BC in forum DIY Showroom
    Last Post: 16th June 08, 07:41 AM
  4. style question - tartan flashes, solid flashes or no flashes?
