Results 1 to 10 of 11
    22nd November 07
    Desert SW USA
    An Actual Kilt Question: Loose Fringe Apron Thread?
    The other day, while brushing down my kilt to put it away, I noticed a vertical thread had come away from the fringed apron edge. It got caught in the brush and had un woven down most of the fringe. I seem to remember this happening once before when I first got the kilt; it's a Stillwater wool. I hadn't worn it for about a year.
    What should I do to the fringed edge, if anything?
    Victoria, BC, Canada
    Ted,
    Simply cut off the offending thread with some scissors and forget about it.
    It sometimes happens that not all the yarns get pulled when creating the fringe and one or two come loose after time.
    It is not a problem and should not be a concern.
    Now, if a lot of threads start coming out you may have a problem. Usually a quick run through a sewing machine will fix it. Any alteration shop can do this for you in three or four minutes.
    www.Freedomkilts.com
    2nd Laird of Lochaber
    2nd October 07
    Had that happen on several of my kilts. What Steve said has held to be true for me on every occasion.
    22nd November 07
    Desert SW USA
    Thanks, the thread was just attached at the very bottom when I pulled it off.
    Last edited by Bugbear; 24th March 11 at 07:52 PM. Reason: Wouldn't let me post it.
    26th November 04
    Dayton, OH
    That happened on St. Patrick's day to my Irish National kilt. Quick snip with the scissors and all is well. It does not look like any more will pull away.
    Mike
    22nd January 10
    London UK
    Yes it would still hold on to the selvedge as this is the strongest part in the weaving... so jest just carefully cut it off.
    Schiehallion kilted and true
    22nd November 07
    Desert SW USA
    I just cut it off even with the fringe. There are two offset rows of fringe and it was the top row.
    16th October 08
    Albuquerque, New Mexico
    Quote Originally Posted by Bugbear View Post
    Run, scream, gnash teeth, cry soulfully, lament at the injustice of it all, then snip the offending thread and be done with it. .....oh i see you did, nevermind. ;oP
    Rabbit, What Rabbit? I should'a turned left at Albuquerque!
    One Life, One Mind, One Peace.
    22nd November 07
    Desert SW USA
    Quote Originally Posted by BroosterB1 View Post
    That reminds me, I still need to write and insert a large footnote or paragraph regarding that UU book I asked you about the other day; lots of good stuff in there. Been a little busy over the last couple of weeks with the computer crash.
    Anyway the kilt was fine after a year of hanging there, and I still remembered how to put it on.
    16th October 08
    Kilts are kind of like that, always willing to be put back on, even if you are wearing white hose. :oP
  1. X-Kilt Under Apron Question
    By Eleazar in forum DIY Showroom
    Last Post: 27th January 10, 04:57 PM
  2. A question concerning the fringe on an apron
    By Doftya in forum DIY Showroom
    Last Post: 3rd October 09, 07:15 PM
  3. X-Kilt under-apron modification question
    By Dave K in forum DIY Showroom
    Last Post: 28th February 09, 10:43 PM
  4. Kilts with fringe around the apron?
    By Kizmet in forum General Kilt Talk
    Last Post: 28th June 06, 03:21 PM
  5. Apron question
    By Alan H in forum Kilt Advice
    Last Post: 16th February 05, 05:11 AM
