Results 1 to 10 of 15
Thread: Alterations
    24th February 09
    Houston, Texas
    Alterations
    How is the best way to alter the length of a kilt by 2 inches? Considering the pleats, is it more labor/cost effective to hem the kilt at the bottom or at the top and move the buckles?
    Wesley Tennyson
    ... I have felt the wind of the wings of madness...
    Charles Pierre Baudelaire
    30th June 06
    Lotusland, Canada
    Just one fat, old mans opinion...................
    Find a good tailor or seamstress in your area. Hem from the bottom, not sure what the stitch is called, maybe a blind hem stitch. Don't cut the material in case you grow or want to sell the kilt later. As long as you don't mind a hemmed selvedge, it works and still looks good. I had this done to an SWK standard and later had it removed as I changed the way I wear that kilt. Cost was $34.
    Gentleman of Substance
    Victoria, BC, Canada
    Please understand that the way you alter the length of a Kilt by 2" will all depend on the type of Kilt you have.
    You didn't say what kind of Kilt you are trying to alter.
    To better advise you please let us know a little more.
    www.Freedomkilts.com
    2nd Laird of Lochaber
    19th March 09
    Astatula Florida
    True advise from both the above, if you ever plan to change again"Don't Cut It"
    19th October 07
    New Castle,CO.
    I had several of my SWK standards altered for $30 each. They were hemmed by the blind hem stitch. It is hard to tell from even up close that they are hemmed and the extra material at the bottom is no big deal. The lady I use out here does an excellent job.
    Nulty
    Kilted Flyfishing Guide
    14th January 08
    Goshen, KY
    You described your action as "altering the length of the kilt by two inches" which so far everybody has taken to mean that you desire to shorten it by two inches. If so follow thier instructions. If, however, you intend to TRY to LENGTHEN a kilt by two inches, contact your local miracle worker, as unless you have a magic wand it is not likely to be achievable. Unless you consider wearing a trad as a casual and pulling the waist down to the level of your hips instead of up at your navel. Not a good look.
    This from a man who is 6'5" and constantly finding good deals on 24" kilts that are too short with no hope of ever getting them lengthened.
    wsk is offline This member has been inactive for more than 1 year
    18th November 06
    40° 30' 27.3" North 111° 24' 47.9" West 5595 Feet
    Read Barb T's book. Hem the bottom with a herringbone stitch. The kilt between the waist and the fell needs to stay as it is. Moving the kilt up by moving the buckles moves the bottom of the sewn pleats up. When you do that, the unsewn pleats no longer hang correctly and will look bad.
    You will need to undo the facings on both the apron and under apron (not all the way, just enough to do the hemming). You'll need to undo the adjustments to the points of the deep pleat and the under apron. Then hem the kilt and redo the things you undid. Barb Ts book explains how to put it together.
    24th February 09
    Houston, Texas
    The kilt is a Balmoral lightweight 8 yard
    Kilt length: 24" / 61.0 cm
    Kilt seat: 44" / 111.8 cm
    Kilt waist: 40" / 101.6 cm
    Stitching: Hand & Machine sewn
    Wearers height: 6ft 0 inches
    Tartan: MacThomas Modern (batli/11oz/150cm/Batli Cuillin Light Weight)
    The kilt will be professionally altered. I want to make sure I provide the correct instructions.
    Thanks for your advice.
    Wesley Tennyson
    17th December 07
    Staunton, Va
    Something's not right here... I'm 6'1. My kilt measurement is W40/S45 and, measuring four of my kilts, the length is 26 (3 kilts) and 25 (one kilt). Now these kilts just brush the top of my knee. A 22 inch length on a six-footer would seem to me to be pretty short, possibly a couple of inches above the knee. It might work if the kilt is intended to be worn below your natural waist (like a pair of jeans), but if you wear it at your natural waist I think you are going to need more than 22 inches. Are you sure about the desired length?
    24th February 09
    Houston, Texas
    Which kilt is the correct length?
    22 inch:
    or the 24 inch:
    Sorry the photos are so large...
    Last edited by tennysonw; 28th April 09 at 08:55 AM. Reason: My photos would not post
    Wesley Tennyson
  1. Kilt Alterations?
    By Aramp in forum Kilt Advice
    Last Post: 31st August 06, 09:36 AM
  2. UK alterations
    By longshadows in forum Kilt Advice
    Last Post: 9th May 06, 10:08 AM
  3. Jacket alterations
    By Tartan Hiker in forum How to Accessorize your Kilt
    Last Post: 8th February 06, 08:16 PM
  4. Kilt alterations?
    By Jerry in forum Scotweb Kilt Store
    Last Post: 25th January 06, 10:25 AM
  5. Kilt Alterations
    By Sir Robert in forum General Kilt Talk
    Last Post: 11th November 05, 11:46 AM
