14th April 09, 07:47 PM
Argyll Kilt?
Ok, so every tartan kilt I've ever seen has the tartan angled horizontal/vertical.
Has there ever been one with it angled diagonally, like Argyll hose for example?
I assume you would have to order/weave the tartan in square units of measurement, and then cut off the corners so that it becomes a large rectangle, and then continue the standard kiltmaking procedure.
I personally think it would look astonishing, imagine the pleating possibilities!
Isn't it amazing how food can sound so good just by having absolutely no clue of what it is?
14th April 09, 08:11 PM
I'm no expert on kilts, but I doubt it. That would be putting the fabric on the bias which would probably be harder to pleat and would definitely fit differently not to mention cost a LOT more because you are only able to use a certain section of the fabric. But maybe I should defer to one of the *many* kilt making experts here...
I have a fever, and the only prescription is MORE KILT
Running Barefoot: Not just for children anymore.
14th April 09, 08:43 PM
I could see potential... but it wouldn't be easy. It would definitely set you apart.
14th April 09, 08:52 PM
This would look pretty cool. It would be a ton of work to make it into a kilt. You'd have to make a lot of diagonal pieces into squares.
14th April 09, 09:01 PM
I must admit, seeing the MacGregor on a bias does pique my interest.
'S Rioghal Mo Dhream
14th April 09, 09:04 PM
Pleating to a line would look odd... but to the sett the front would look just like the back just one having pleats.
14th April 09, 10:28 PM
Um... I've read about lady's tartan skirts being cut on the bias, but never a kilt.
15th April 09, 01:47 AM
It would certainly look strikingly different and would match a tie and hose which go at the same angle.
15th April 09, 03:27 AM
The kilt would certainly have a great look (although pairing it with any matching items might be overkill).
I'm not sure it would work well, from a mechanical standpoint. Suspect that the pleats would be constantly fighting to return to vertical thread alignment, that is, they might want to hang "sideways." Or maybe not -- hard to tell until some brave soul makes a go at it!
15th April 09, 03:31 AM
I'm still thinking of switching to Roman skirt armor...
By KiltedDawg in forum Contemporarily Made Kilts and How to Wear Them
Last Post: 29th March 09, 03:19 PM
By beloitpiper in forum Kilt Advice
Last Post: 6th January 09, 11:28 AM
By Kiltedmusiclover in forum Kilt Advice
Last Post: 12th August 06, 01:51 AM
By JBfromBS in forum Kilt Advice
Last Post: 29th August 05, 03:30 PM
