Results 1 to 10 of 11
Thread: ceramic kilt?
    27th January 05
    Jefferson, Georgia, USA
    ceramic kilt?
    The company I work for manufacturers fire barrier products which incorporate a ceramic cloth.
    The feel of this material is very satiny so I think the swish factor would be awesome. The material weighs a ton though. I can't imagine an 8 yard kilt in this material. A 4 or 5 yard kilt might be do-able. The other issue is comes in a white-ish silver color. I need to find out if it comes in black.
    Can you imagine a flame retardent kilt. Might be somehting for the blacksmiths in the crowd
    Caradoc's Avatar
    Caradoc is offline This member has been inactive for more than 1 year
    18th April 06
    Phoenix Metro Area, AZ, US
    Quote Originally Posted by cavscout
    I can't imagine wearing that stuff on/near bare skin for any length of time. The ceramic cloth I've worked with in the past had a nasty tendency to leave fiberglass-like splinters in exposed skin.
    Inter spem curamque, timores inter et iras
    Omnem crede diem tibi diluxisse supremum:
    Grata supervenient, quae non sperabitur hora.
    14th December 05
    Coeur d Alene, ID
    Well, there is always Nomex...
    Phil in Idaho
    3rd March 06
    A long time ago in a kilt far, far away
    something about wearing a pleated vase scares me...
    27th January 05
    Quote Originally Posted by Caradoc
    I had wondered about that also, but it felt so smooth I don't know if it is the same stuff. Even the trimed edges feel pretty soft, not prickely like I imagine fiberglass.
    Caradoc's Avatar
    18th April 06
    It does, at first. The more you "work" with the cloth, the more the fibers break down.
    Like I said, it's been a while since I've worked with the stuff, but it felt nice and smooth until it had been folded and refolded a couple of times, and then I ended up having to use a wad of duct tape to pull splinters out of my hands.
    After that, I used gloves all the time while handling it. Further research indicated I should have been using a respirator, too, as inhaling the fragments is bad for the lungs.
    Can you find an MSDS on the material?
    27th January 05
    Here's an information sheet on it.
    The abridged version is:
    Tests indicate it is not a hazard to inhalation but can irritate skin.
    Guess it would have to be lined with an "under kilt", or might work as a protective apron to be worn over a kilt.
    Caradoc's Avatar
    18th April 06
    The line "Contaminated clothing should be laundered each day" indicates to me that it wouldn't be useful for anything I do - a simple welder's apron suffices for some of the stuff.
    Nomex would be nice, maybe. Or Kevlar.
    27th January 05
    Looks like Nomex is dyeable. Anyone work in an industry that uses this stuff off a roll?
    5th September 05
    Chicago
    Uh...just because you can do something doesn't neccesarily mean that you should do it...how about kevlar?...bulletproof! "Aim high, boys, they're wearin' bulletproof kilts!"
    Best
    AA
