Results 1 to 8 of 8
Thread: Is this common?
    15th October 09
    Dallas area
    Is this common?
    Morning all,
    I now have kilts from 4 different makers and I seem to have the same issue on all 5 kilts. On the left hand side of the apron it always curls forward. On the hanger straight, freshly ironed looks good on the board but as soon as I put them on the front does it's curl thing.
    Jim
    I cook with a flair for the dramatic,
    and depraved indifference to calories
    14th January 08
    Goshen, KY
    Most likely a measurement issue----if your hips are larger than the kilt is built for you (ie you are actually a true 38 but the kilt hip is built for a 37 or 36 instead) you will get that "flying" pleat of the first pleat at the reverse pleat. A sign that you have recently gained weight or that you need to use a slightly higher hip measurement next time you order a kilt.
    It can also be brought on if you tighten your bottom right hand strap too tight, which mimics having too small of a hip built inot the kilt. So try that first.
    j
    24th November 05
    Clodine, Texas
    Lightbulb
    Fairly common, here's a thread about it;
    http://www.xmarksthescot.com/forum/f...n-flare-59053/
    11th March 08
    New Jersey
    Quote Originally Posted by ForresterModern View Post
    That was my thought as well. If you're really ratcheting down the lower strap, that can cause pulling on the apron.
    "To the make of a piper go seven years of his own learning, and seven generations before. At the end of his seven years one born to it will stand at the start of knowledge, and leaning a fond ear to the drone he may have parley with old folks of old affairs." - Neil Munro
    22nd November 07
    Desert SW USA
    Ya, Barb explains what to do in the link Zardoz posted if the apron is flipping.
    * Never mind the following if you don't have the lower straps. *
    However, the right lower buckle of my kilt was also placed too far over and it caused flipping open problems with the first and second pleats after the apron on the left side, as well as the apron; I had to move it. I suppose it could just as well be the tight lower strap causing the problem.
    Last edited by Bugbear; 18th October 10 at 10:14 AM. Reason: Fixing wording, and adding note.
    15th October 09
    Dallas area
    j
    I wish that were the case but two of the kilts have no bottom strap.
    I was wondering that since I do have an unusual build for a guy, I actually have a rear. Can it be that the pushing on the front from the belly vs the pushing out the back from the butt is doing it? I had my wife do the measurements per the instructions and made sure she did pull the tape tight. When it comes down to it the hip (on me is lower due to the butt) is the same as my waist. Causes problems in anything but relax fit pants since if it fits my waist (vs the abdomen for the kilt) it won't fit the legs or rear. I think the PC name is an atletic build. I had this issue even when I was 160ibs.
    It is not to bad, just a little flip but I was noticing it on all of the kilts.
    Thx,
    Jim
    24th November 05
    Clodine, Texas
    Question
    Drac, correct me if I'm wrong, but it sounds to me that when you are talking about "hip" vs. "butt" you are saying that your "hip" measurement is smaller than your "butt" measurement would be ? If that is the case, that might be part of the issue. Measuring guides vary, but generally the "hip" measurement is done around whatever the largest part of your hips, butt etc. and some makers tell you to do that one with a finger under the tape.
    15th October 09
    Dallas area
    Correct, my hips are smaller but I did measure at the largest partwhile is several inches lower than most diagrams.
    I am hoping as I lose weight that it will be less. It's a slow process but on it's way for both my health and the Navy.
    Thx,
    Jim
  1. Undaunted by Common Sense!
    By Kid Cossack in forum General Kilt Talk
    Last Post: 12th November 06, 06:17 PM
  2. Common Sense
    By Southern Breeze in forum Miscellaneous Forum
    Last Post: 13th April 06, 06:21 AM
  3. How common are kilts in Australia?
    By Iolaus in forum General Kilt Talk
    Last Post: 13th September 05, 09:42 PM
  4. Common Questiins Page
    By richardljohnson in forum Comments and Suggestions
    Last Post: 27th June 04, 05:14 AM
