Results 1 to 7 of 7
Thread: Dying Wool?
    Casper's Avatar
    Casper is offline This member has been inactive for more than 1 year
    25th May 07
    Port Moody, British Columbia, Canada
    Dying Wool?
    Quick question... how hard would it be to either dye myself, or have dyed, a wool kilt jacket? I've found some vintage ones that are incredibly cheap, but in some rather hideous colours...
    "Its Better To Be Hated For What You Are, Than Loved For What You're Not."
    - Andre Gide
    14th January 07
    Check with your local dry cleaner they should be able give you an idea. In general the concept
    See what they say here.
    http://www.peak.org/~spark/dyeingfelt.html
    Lets us know how it goes.
    14th March 06
    cold dying
    I have never done it, but I understand that wool can be dyed with cold dye.
    Of course, if the colors are hideous now, they might become even moreso with dying. The practical thing to do would be to dye a swatch first, but I would guess that probably isn't possible.
    Casper's Avatar
    25th May 07
    Well, the goal would be to go from a nasty green, to black. In theory, it should more or less dye over whatever colour that's currently there...
    - Andre Gide
    4th September 05
    Oklahoma
    One problem that you can run into when dying a finished garment is that the thread may either not take the dye at all or may take it differently than the material, which can cause the stitching to become much more visible than you might want. It's a good idea to test the dye on an unobtrusive spot of both material and stitching and see how it turns out.
    --Scott
    "MacDonald the piper stood up in the pulpit,
    He made the pipes skirl out the music divine."
    Check out my T-shirt designs!
    30th June 06
    Lotusland, Canada
    Quote Originally Posted by Casper View Post
    I definitely would recommend AGAINST dyeing yourself! Your are just right being that wonderful caucasian, off-coffee colour!
    As for the jacket, I have no idea!
    Gentleman of Substance
    I used to regularly dye wool for my knitting projects - it is not difficult with yarn and patience, but you need to have the stuff absolutely clean before you start - an invisible food or grease stain can either take up or resist the dye and become very visible.
    You need the right dyes for wool, and to have a large container as a dye bath, and be prepared to spend time concentrating solely on the dyeing process.
    Black is a difficult colour to get, it requires loads of dye, far more than dark brown, or deep green for instance.
    I used to do a lot of dyeing in my hippie days to create things not available in the shops, and used dye strippers, which would literally remove the colour from any surface dyed fibre - some man made fibre is dyed in the vat before it is extruded, so the colour is permanent. That was useful for removing enough colour so that it could be altered or used as a background for other dye effects.
    If you can strip out the dye you would then have a lot more options on what colour to dye the jacket, and the result would look cleaner and brighter than over dyeing.
    At each stage of the process you need to wash out the chemicals thoroughly - otherwise in a few months the residues can rot the material and it literally falls apart.
    If you can get hold of the jackets cheaply then you can experiment to find a good method of dyeing without losing much if it all goes wrong.
  1. Dying a Fur Sporran
    By AL-58 in forum DIY Showroom
    Last Post: 11th June 07, 01:19 PM
  2. dying a utilikilt
    By Kilted KT in forum Kilt Advice
    Last Post: 15th April 07, 06:30 AM
  3. PV vs Wool
    By David in Maryland in forum Kilt Advice
    Last Post: 31st January 07, 02:21 PM
  4. Another friend dying
    By Graham in forum Miscellaneous Forum
    Last Post: 2nd November 06, 07:46 PM
  5. Asking for More Info on Dying Kilt Hose
    Last Post: 17th October 06, 09:36 AM
