Results 1 to 10 of 21
    21st June 14
    North Yorkshire ye olde England
    Glengarry.....how and wear to attach a badge?
    Picked this Glengarry up from an Aberdeen store, thought i'd wear it for remembrance Sunday as two of my great grandparents were in Scottish regiments. I had wondered about attaching a cap badge and or where you attach them? I do have two badges KOSB & A&SH but as they're in photo frames with ww1 medals seems a hassle to mess on taking one of them out of their respective frames so I may just use my crest badge but again thinking about how its attached. Any good photo examples?
    https://imgur.com/a/njJufQk
    13th June 07
    Hoschton, GA
    Cap badge on a Glengarry
    Look at this picture on the USA Kilts web site.
    https://www.usakilts.com/glengarry.html
    "I'm not crazy about reality, but it's still the only place to get a decent meal."
    Grouch Marx
  3. The Following User Says 'Aye' to kiltedsawyer For This Useful Post:
    30th September 08
    Cypress, Texas
    Like this...
    I don't wear a Glengarry, but I'd think you'd pin it on just as you would on a Balmoral:
    Hope that helps!
    SM
    Shaun Maxwell
    Clan Maxwell Society
  5. The Following User Says 'Aye' to ShaunMaxwell For This Useful Post:
  6. #4
    2nd May 08
    Mandurah, Western Australia
    Centred on the cockade /rosette, like this:
    If your going to use a clan badge with a brooch type pin just pin it to the cockade ribbon. If you're going to use a military badge with lugs and cotter pin you will probably need to punch holes right through.
  7. The Following 3 Users say 'Aye' to Bruce Scott For This Useful Post:
  8. #5
    21st June 14
    Thanks chaps so i'm going to assume that a GG has prepunched holes to allow lug style badges with pin fittings or if not do you have to make these yourself? Sounds pretty invasive if you have to do it yourself. Simple enough if your badge already has a pin and lock mechanism but I know the old ww1 badges like the Argylls and King's Scottish Borderers are lug style fittings.
  9. #6
    2nd May 08
    Quote Originally Posted by TenorClef View Post
    I mounted a lugged badge on a glangarry by poking two holes through all layers of fabric with a large diameter awl. It may sound a bit drastic but once it's on it's on, looks fine and I have no intention of taking it off .
  10. #7
    21st June 14
    Yikes sounds brutal I'd really like to attach this to my GG
  11. #8
    21st June 14
    Had to order some of these too to attach to reverse of badge lugs.
  12. #9
    2nd May 08
    If you can get hold of punch like this it will be less brutal
  13. #10
    The punch would be removing material, I would favour using an awl and gently separating the fibres.
    I also recommend testing the effect before the day to see if the fabric will take the weight without slumping as some badges are quite hefty.
    You might need to add a rectangle of something more rigid to help the ribbon - I would cut out a piece of leather sturdy enough for the job - having that sort of thing to hand, but if nothing else then a couple of layers of card, in best 'Blue Peter' tradition would be better than trying to deal with a badge drooping or swaying around.
  14. The Following 6 Users say 'Aye' to Pleater For This Useful Post:
