Results 1 to 10 of 10
    27th October 06
    Snellville, Ga
    Help please! Hole in kilt
    I am so stupid, while sitting down this evening, I pulled part of my kilt pin through the fabric of the apron, leaving a small hole. What do I do now to ensure that the hold doesn't fray or is there a way to repair it??
    Help!
    18th December 06
    Burlington, Ontario, Canada
    Is it a tear or was the weave just opened up? Some people on this forum have touted the stuff called Fray Check that would stop any further raveling. This make make that area stiffer though.
    The Grant.
    3rd March 06
    A long time ago in a kilt far, far away
    buy a new kilt to use as parts to repair the old one.
    9th June 06
    New Mexico
    Bummer! Which kilt was this? I don't wear a pin often (because of fear of this very thing.)
    “A proud man is always looking down on things and people; and, of course, as long as you're looking down, you can't see something that's above you.” -C.S. Lewis
    27th October 06
    Snellville, Ga
    It was my brand new MacKinnon kilt.... Bummer indeed.
    3rd February 06
    Springfield,Oregon
    Where did you get the kilt,and have you thought of contacting them to see if there is something they might be able to do, to help? Just a thought.
    Caradoc's Avatar
    Caradoc is offline This member has been inactive for more than 1 year
    18th April 06
    Phoenix Metro Area, AZ, US
    Quote Originally Posted by Splash_4 View Post
    Help!
    I've seen a number of kilts that have had a piece of grosgrain ribbon in a coordinating color sewn on where the kilt pin goes.
    That might work for you. Covers the hole, looks good, and gives a better surface to pin to.
    Inter spem curamque, timores inter et iras
    Omnem crede diem tibi diluxisse supremum:
    Grata supervenient, quae non sperabitur hora.
    Doc's Avatar
    Doc is offline This member has been inactive for more than 1 year
    10th March 07
    redding,CA
    My gramps used to back the apron with ribbon and then hand stitch small button holes for his kiltpins, he never went without. I think the pin would fail before the apron ripped. You had to look pretty close to see the holes when the pin was off.
    Doc
    Di! Ecce hora! Uxor mea me necabit!
    Jugglito ergo sum.
    Martin S Guest
    There are -- alas -- Scottish-made kilts with poor quality wool.
    I have one that is very soft, and holes appeared around the kilt pin in no time. I now never put a pin on this one. The cloth was woven by Strathmore, and I would not buy another from there.
    (I'll put the story of this kilt in another thread "caveat emptor" -- if I can find the "new thread"" button!)
    On my other kilts, I wear a pin only where there is sufficient thickness (double or triple) to take the weight. Some have not enough cloth folded back at the fringed edge of the apron to allow this.
    Martin
    1st April 07
    Between Phx and Flagstaff
    Possible repair option?
    (Emp. Added)
    Splash 4, if you have access to a "reweaver" person that might be a repair option?
    This came to mind because I had a one worsted wool suit with its 'vent' in the front, and I managed to rip the vent seam getting into a car. A friend knew of a "reweaver" (who, IIRC, worked in conjunction with a dry cleaning/alteration place) and suggested having the ripped part of the fabric "rewoven" would be an invisible fix. Lucky for me - it was
    As I understood the proceedure, individual threads are pulled or somehow removed intact from other seam allowances and then used to actually re-weave the tear, hole, burn and whatnot. This has been some years but at that time it was not prohibitively expensive even to my then-budget.
    'Might be worth looking into?
  1. Watering hole in Africa - webcam action
    By Iolaus in forum Miscellaneous Forum
    Last Post: 31st May 09, 08:22 PM
  2. 7 hole Doc Martens
    Last Post: 17th February 07, 05:37 AM
  3. Hole in one!!!...uhm...almost
    By Robin in forum Show us your pics
    Last Post: 28th September 06, 05:38 AM
  4. Fixing a hole?
    By auld argonian in forum Kilt Advice
    Last Post: 23rd August 06, 04:53 PM
