Results 1 to 10 of 24
    ScottInNewHampshire's Avatar
    ScottInNewHampshire is offline This member has been inactive for more than 1 year
    31st December 06
    Exeter, New Hampshire
    How low should it go?? Sporran that is.
    Been trying to find the right place for the sporran. If it's too low in the front, it bangs from leg to leg when I walk. If it's too high, then it doesn't help to weigh down the aprons when I sit. Maybe it just takes practice to find the right spot. Any advice?http://www.xmarksthescot.com/forum/i...n_rolleyes.gif
    14th March 06
    The traditional place is over the genitals.
    I have read that it evolved from a piece of armor that protected them, but don't remember where. Could be more fanciful history.
    Victoria, BC, Canada
    The sporran is not what causes the apron to fall between your legs when sitting you use your hand to do that.
    Many new people wear their sporran too low. It should not bang your legs or swing around wildly when walking. It should also not cause your aprons to bunch up under the sporran. If you find you need to smooth your apron after a few minutes of moving, your sporran is probably too low. A good rule of thumb is;
    With the kilt at normal, traditional height, above the naval, your sporran should hang just under your naval and just above your genitals.
    I suggest you take a look at Hamish's photo albums. Anytime I have a question about the proper and/or appropriate wear of the kilt I look at how Hamish does it first. Then I go from there.
    You can also look at Hamish's video on sweeping the pleats and sitting which is a sticky post here.
    www.Freedomkilts.com
    2nd Laird of Lochaber
    21st November 06
    Margaritaville
    I was always taught a hand's breadth beneath the belt buckle. However, I've found that being a bit bulkier than a traditional piper, I wear it better a bit higher than that, so it doesn't accentuate that feature of my anatomy.
    As for sitting, I spread my legs then close them, to draw slack into the aprons. The sporran only comes into play with my horeshair.
    I would second that, anytime I have a query as to whether I am wearing something correctly all I have to do is check out Hamish's photo album
    here is the link:
    http://hamish.imff.net
    15th August 04
    The top of my sporran sits 2 inches below my navel. Or there abouts. I am kinda a big fellow, and this keeps things from bunching up when I move or banging around when I walk.
    8th February 04
    Quote Originally Posted by PiobBear View Post
    This is how I tell people to wear it... 4 fingers below the buckle as a rule of thumb.
    Rocky Roeger
    Owner & Kiltmaker
    www.USAKilts.com
    15th August 04
    If I wore my sporran the full width of my hand below a belt it would hang way to low.
    Always remember there are exceptions!
    3rd March 06
    A long time ago in a kilt far, far away
    Quote Originally Posted by RockyR View Post
    that's the rule I use. Any further down and my legs get a beating. Highter and it winds up being a second belt.
    Andrew Breecher's Avatar
    Andrew Breecher is offline This member has been inactive for more than 1 year
    4th June 04
    Boston, Massachusetts
    I simply wear my sporrans where they feel comfortable. The "hand's width below the belt" is a good starting point, and adjust from there. My different sporrans each have a "sweet spot" where they hang, and they are each a little different, since they're each shaped differently. I have a different sporran strap for each. I've made use of a leather punch to put buckle holes in exactly the spot where they're comfortable.
    Andrew.
  1. Sporran chain vs. Sporran leather strap
  2. got my sporran belt in 2 days (for freelander sporran)
    Last Post: 12th December 04, 09:51 AM
  3. sporran straps for freelander sporran
    Last Post: 2nd December 04, 03:52 PM
