Results 1 to 10 of 19
    17th October 05
    Longueuil, Québec
    Question Kilt in courthouse
    Hello everybody,
    Should be a good idea to go kilted at the courhouse to testify as a eyewithness ,expert withness or watching a trial?
    The dress code at the courthouse specifies that you have to be properly dressed.
    Does anybody on the list have some experience about it.
    Pierre 'IQ89" Arpin
    AKA The unclonable
    www.iq89.com
    -----BEGIN GEEK CODE BLOCK-----
    Version: 3.1
    GG d-- s: a++ C++ U--- P L- E-- W+++ N o K- w+ O--- M-
    V-- PS PE- Y+ PGP- t+ 5 X R* tv- b++ DI D-- G e++ h+
    r* y-
    ------END GEEK CODE BLOCK------
    chasem's Avatar
    chasem is offline This member has been inactive for more than 1 year
    30th March 05
    Near Santa Fe, New Mexico
    I'm pretty sure there's a member here go works in a courthouse and wears a kilt often.
    28th May 06
    Florida
    Not sure I would do that.
    The last thing you want to do in court is bring more attention to yourself.
    Judges don't like anything that takes away from the matter at hand.
    Be on the safe side and put on the dark suit with a dress shirt and tie. Polish your shoes too.
    Saol fada aqus...rath ort
    "Live long and prosper"
    Andrew Breecher's Avatar
    Andrew Breecher is offline This member has been inactive for more than 1 year
    4th June 04
    Boston, Massachusetts
    I would say: of course! Kilts are "proper dress".
    However, also keep in mind that most people aren't used to seeing kilts. They will see you, and immediately they will draw a conclusion about you. Perhaps it will be good, perhaps it will be bad. Remember that court is about the presentation of facts with as little outside influence as possible. Use your own judgement.
    Andrew.
    3rd June 05
    The beautiful Catskill Mountains of Upstate New York
    My job takes me to a courthouse most Mondays. I've never worn the kilt.
    If you're testifying as an expert, I'd say you owe it to your client to put forth the most professional appearance you can. Unfortunately, the kilt does not do that.
    If you're a spectator or an uninterested witness, go right ahead.
    Most courthouses have metal detectors and security screening. Leave the sgian dubh in the car and be prepared for the possibility that they will not allow your kilt pin (if it's the pointy kind) in, either.
    I work part time as the legally qualified assessor in a Scottish District Court where I usually wear an all black heavyweight kilt with a black tie and black Argyle jacket, along with my court robe. Bear in mind that while you are in the witness box your kilt won't be visible and it will only be seen briefly by the judge when you first walk into the court room - so the top half of your attire is of greater importance. I'd say no problem with wearing a kilt in court so long as you feel comfortable and confident in it.
    switchblade5984's Avatar
    switchblade5984 is offline This member has been inactive for more than 1 year
    8th November 05
    Fresno, CA
    kep us posted!
    bubba's Avatar
    14th February 04
    Little Chute, Wisconsin
    If I were called into the court for any reason they'd have no choice but to accept the kilt. The only pants I have left are grease and paint stained work pants.
    Blu (Ontario)'s Avatar
    Blu (Ontario) is offline This member has been inactive for more than 1 year
    22nd January 04
    Southwestern Ontario
    Several years ago, I contemplated wearing a kilt to jury selection. My thinking was that I would be seen as an eccentric and be subsequently passed over - I did not want to have to take the time off work. At the last minute I "chickened". As it turned out, I was not chosen anyway. If it happens in future, I would certainly consider the option once more.
    8th November 05
    Fresno, CA
    i think it would depend on case......
    so take it on a case by case basis!
    watching go for it.....
    jury selection go for it
    as for testifiying..... depends on the circumstances
    you be the judge!
