Kilt Ironing...
I don't know if I should put this into the General Kilt Talk or the Advice forums, but I came up with an idea that makes ironing out creases and minor wrinkles in your kilts a breeze.....
I've noticed that various women I've dated have used many hair styling products and tools.. One of them is the "hair straightener".. It's essentially a FLAT currling iron type of device.. To me, it was the PERFECT solution to ironing out the pleats in my kilts when hanging!! The only problem is that these things don't steam so you have to "mist" the pleats with a spray bottle first..
I tried this last night on my Utilikilts and Amerikilt and it worked great!!! The Iron only cost $9.00 at Target, too!!
Here's an example of one similar to the one I bought.
Hi folks
If you try this on a wool kilt, I'd test it on the inside before going anything on the outside. You might need to put a piece of cloth between the jaws of the straightener to avoid getting a shiny spot on the wool. Don't know, but I'd be careful.
Barb
 Originally Posted by Barb T.
Hi folks
Barb
Thanks for the advice.
Barb, If you have a wool kilt that has been badly ironed and there are already shiny spots, can these be fixed with wet towel pressing or is the damage permanent?
To some extent, it's permanent
If I'm remembering correctly, the shiny spots from overheating wool with an iron are caused by actually melting the wool. If the burn isn't too bad and the fabric has some pile (such as with a sweater), you can hide the damage by "brushing up" the fabric using a clean, damp toothbrush and light hand. I'm not sure how that would work with a finer fabric such as a kilt, but I think the results would be worse than a shiny spot.
Need something to go with your kilt? Try KiltWear!
yes you have to be careful while ironing wool shiney bad
What an incredible idea! My wife bought one of those useless things about two years ago and maybe used it once as did my niece and it has collected dust ever since. Suddenly I see it in a new light and I will try it on my kilts this coming week-end. It's a top of the line with temperature controlled ceramic plates and all the bells and whistles but I never thought to put it to that kind of work and the best thing is that I won't get any flak from my wife since she has never had any use for it since the first time she used it.
Thanks,
Chris.
Thanks,
Chris.
Don't forget to mist the fabric before using this to iron your pleats.
I'm glad I could think of something that someone else would find useful!!!
That's why I love steaming, no shiney spots but damn crisp lines if you do it right.
Clan MacKay & Proud Of It!
[B]Interested in seeing what I do? Visit
10th May 06, 10:15 AM
I won't and you did,
Thank you.
Chris.
