12th July 10, 08:54 AM
Kilt strap extenders
Greetings all,
This may very well be in the wrong forum and, if it is, I apologize.
I am looking for some brown kilt extender straps that are 1" wide. These are for a set of boots I recently acquired that have leather buckles on them. Unfortunately they do not fit around my legs and are in need of some assistance.
I am only able to find .75", 1.25", and 1.5".
These are the boots in question:
12th July 10, 08:56 AM
You best bet is to take them to a local cobbler or bag repair shop.
They'll be able to help match the leather and style (as well as any stitching).
12th July 10, 08:58 AM
artificer,
I will have to look into that. I am not too concerned about the leather style and stitching since I am not planning to wear these anywhere where it would matter.
12th July 10, 09:00 AM
What length do you need the extenders?
12th July 10, 09:02 AM
Strap Extenders - Local & Thifty
Suggest the same method I used for getting low cost extenders for my kilt.
Go to local thrift or re-sale shop and check out theire selection of used belts.
You may be albe to find a selecton of belts that are correct width and color.
Then cut the belt to desired length and punch new holes.
I was able to buy three belts, at fifty cents each, that are now my kilt extenders.
Kaw-Liga
12th July 10, 09:07 AM
cavscout,
Not much more than 2". The end of the current straps just touch the edge of the buckle.
Kaw-Liga,
That is a good idea. There should be some female belts out there that are only 1" wide.
12th July 10, 09:18 AM
You might consider using Chicago Screws to simply attach the few inches needed to the existing strap through the existing holes. Then you won't have another buckle involved. They come in black, nickel and brass.
12th July 10, 09:34 AM
cavscout,
So just those and some 1" wide leather with holes in it? Sounds brilliant.
12th July 10, 09:55 AM
Yep, it's just crazy enough to work
12th July 10, 10:07 AM
 Originally Posted by ThinBlueLine
cavscout,
Just make sure to use a little 'thread lok' or similar on the screws, they can work themselves loose otherwise.
By M. A. C. Newsome in forum How to Accessorize your Kilt
Last Post: 9th April 09, 04:31 AM
By Kilted Rogue in forum How to Accessorize your Kilt
Last Post: 11th February 09, 06:01 PM
By Squeaky McMurdo in forum Scotweb Kilt Store
Last Post: 1st December 08, 12:33 PM
Last Post: 1st November 08, 02:15 PM
Last Post: 10th October 08, 07:09 AM
