16th January 09, 10:11 PM
kilts and airport security
Looking to find out if anyone out their has worn their kilt on a flight? Any advice for going through airport security specifically with the amount of metal on the kilt and accessories. Besides the obvious no sgian dubh . I have travelled with mine always carry on never trust airports and luggage. The kilt pin has caused a problem occaisionally just 'till I unroll and they can see it. I have never actually flown in the kilt, who has??????
16th January 09, 10:26 PM
I've never flown kilted but I do recall some threads about it. Pack sgian and pin in your check in luggage lest they be confiscated. If you travel frequently you might consider a contemperary kilt with pockets and plastic buckles. Explosive sniffing devices shouldn't be a problem even without a kilt pin, as I understand it it's just a small puff of air out of the less than barely enough to ruffle your pleats.
The Grant.
17th January 09, 03:24 AM
I have flown kilted several times.
There are other threads around already with lots of detail on this subject - do a search using key words like "airport" "security" and "kilts" and you will find them.
17th January 09, 04:59 AM
Yup, last time I flew I was given the royal treatment. I took off my belt, sparron, and shoes. I took my laptop out of the bag and placed it in the tub. I then went thru the metal detector where you have a 50-50 chance to set it off depending on the earth's magnetic field (why else would I set it off going one way but did not set off the detector on the return trip?) So I get pulled aside and given special treatment, ya know like royalty. Then a discussion ensues between my two, yes two, personal security detachment. It seems that one or maybe both have never done a kilted one before. So they start the normal wanding but hesitate at the waist. I can see their thought process, what do I do with that skirt? I pipe in "I am usually asked to pose in a lunge position. My personal security detachment needed some time to discuss it. Upon their decision I was asked to lunge with my left, then lunge to the right (sounds like aerobics). Anyway, pleasant time held by all even though my personal security detachment wasn't allowed to smile while on duty.
17th January 09, 05:10 AM
I've flown kilted several times in the past year. No problems at security - I just remove the kilt pin and place it in the sporran, put sporran and belt through the scanner. I am always wanded because of a large lump of metal in my leg. The TSA people seem to be trained to handle kilts, using the 'lunge' technique ChattanCat descibed.
Brian
17th January 09, 06:09 AM
I never had any serious problem with my kilt while flying. The only reminder might be that they oculd take your pin if there's young persons in the security. According to Brittish law kilt pins are allowed. Otherwise you could just take my personal excuse: "Without the pin my kilt will fly up. And you don't want me to show off?" It's not all true, but there is a root of truth in it.
17th January 09, 07:28 AM
I never set things off when in my UK, Mocker, but always if in a trad with buckles. Just leave enough time to allow for being wanded and searched if it happens, so it can be a relaxed event instead of anxiety that you will miss your plane.
17th January 09, 08:44 AM
Rather than trying to work out which bit of me was setting off the alarms, I once found it quicker and simpler to take the kilt off too.
I have never had any bother at that airport since.
Actually, I have now made myself a buckle-less, metal-less kilt, so I am able to remain dressed when flying.
Martin
17th January 09, 12:37 PM
I fly exclusively kilted (regularly between Sydney and Tasmania) and have never had a problem. The only modification I make is taking my kilt pin off and putting it in the checked in baggage. When going through the detector I simply remove my sporran which contains all my coins, wallet, phone, keys, ipod etc (much much faster easier than rooting through all my pockets).
It's the only way to fly!!!
Scotty
Before you judge someone be sure to walk a mile in their kilt.
That way you are at least a mile away and you have their kilt...
17th January 09, 04:09 PM
Hi all,
I was kilted for the first time to go to Russia in summer 2008.
I took the precaution not to wear the kilt pin and the sgian dhub.
I had only problems with an arrogant security officer back in the USA at JFK when I had to do gymnastics for him. :-(
Nobody in the plane said something. It's not more different to see a kilted guy or a member of any ethnic group wearing its native dress.
Pierre 'IQ89" Arpin
AKA The unclonable
www.iq89.com
-----BEGIN GEEK CODE BLOCK-----
Version: 3.1
GG d-- s: a++ C++ U--- P L- E-- W+++ N o K- w+ O--- M-
V-- PS PE- Y+ PGP- t+ 5 X R* tv- b++ DI D-- G e++ h+
r* y-
------END GEEK CODE BLOCK------
By Randy in forum Miscellaneous Forum
Last Post: 28th August 06, 01:29 PM
By TechBear in forum General Kilt Talk
Last Post: 23rd May 06, 10:46 AM
By andyfg in forum General Kilt Talk
Last Post: 18th May 06, 10:22 AM
By longshadows in forum General Kilt Talk
Last Post: 6th March 06, 07:11 PM
By MtnBiker in forum Kilt Advice
Last Post: 1st September 04, 06:07 AM
