Results 1 to 10 of 17
Thread: Oz. per yard
    14th May 08
    Slovenia
    Oz. per yard
    Excuse me being such an ignorant, but I just can get myself over all those units. Reading many posts describing fabric used for kilt and couldn't get straight answer.
    Here we go...
    Saying 16oz. kilt is meaning what: oz. per linear yard, oz. per square yard...???
    If per linear yard, what fabric width is meant?
    Sorry once again.
    25th May 06
    Kitchener, Ontario, Canada
    Yes, it is ounces per linear yard. The fabric width is usually "double-width" which is anywhere from 54" to 60" wide.
    John Hart
    Owner/Kiltmaker - Keltoi
    10% Discount for XMTS Members (Kilts & Plaids)
    6th February 08
    wait
    So 54" width is double wide???? I can feel my next kilt getting closer!
    25th May 06
    Yes. 54" is usually double-width for heavy weight, medium weight is often 56", and lightweight is usually 60". Single-width is, well, half that!
    John Hart
    14th January 08
    Goshen, KY
    Even though some fabrics are only woven in single width, especially some custom weaves, they are still weight estimated as if they were a linear yard of double width fabric, in order to make the system more consistent. So it would actually take two yards linear of single width fabric to determine the "weight" of that fabric, where it would only take one yard linear of double width to determine the weight of that fabric, since the standard is the wieght of a linear yard of double width fabric.
    Also as Slohairt describes above the lighter the weight of fabric the more the tendency is for that fabric's double width to become even wider---16oz at 54" wide DW, 13oz at 56" DW, 10 oz at 60" DW--although not always. But it does help explain sometimes why a particular weaver's 13 or 16oz fabric does not feel like the same weight as another weaver's of the same alleged "weight". A 16oz per yard of 54" wide fabric should feel a bit heavier than a 16oz yard of 60" wide fabric, about 10% heavier to the hand actually. This can be particularly noticeable when you go from 16oz/yd 54"DW fabric to 13oz/yd 56 or 60" DW fabric, that the 13oz will feel even more substantially less heavy to the hand than the 16oz as its weight is distributed across a greater width of fabric.
    Victoria, BC, Canada
    Another thing you must remember that all this stuff about weights and yardage started a long time ago. We refer to this time frame as BX and AX. (Before X Marks and After X Marks)
    In those olden days, weavers used whatever measuring system they liked, and terms like 160z was just a reference, not a standard.
    So we at X Marks have started to use the terms Fabric Yard and Kilt Yard to refer to the weight of fabrics.
    A Fabric Yard is a piece of fabric 1 yard (36") long and 60" wide as the standard to use for weighing.
    A Kilt Yard is 1 yard (36") long and as wide as your Kilt is long from Hem to Waistband.
    To further complicate matters there are two basic methods to make a fabric heavier. The first is to weave all fabrics with the same number of yarns per inch but change the thickness of each yarn.
    The Second method is the use yarns of all the same thickness but cram more yarns per inch into the fabric.
    They both result in a change of the total weight of the fabric but not always at the same rate.
    This non-standard ways of weighing and listing fabrics has led, in the past, to such phrases as "heavy weight" fabric. Well, it's that particular weavers heaviest weight fabric and has no relation to any "standard".
    Since we at X Marks have begun to "Standardize" our terms and our membership have become used to using some "standard" we are finding the weavers have begun to adopt our idea of a standard. Marton Mills for example gives their weights in grams per square meter. With a simple conversion to ounces per square inch you know exactly what their fabrics weigh.
    www.Freedomkilts.com
    2nd Laird of Lochaber
    14th January 08
    Goshen, KY
    Simple for who? I think I need a fifth grader to help me with the math. No wait, I think I got it.
    30 grams to an ounce
    39.37in per meter = 1550 sq in per sq meter
    36" x 60" = 2160 sq in = 1 fabric yard
    therefore 1 fabric yard = 1.393 sq meter
    so a "fabric yard" of 16oz tartan ought to weigh about 480 grams (or 345 grams per sq meter) give or take, 13 oz tartan ought to weigh 390 grams (or 280 grams per sq meter), 10 oz tartan 300 grams (or 215 grams per sq meter)
    I guess that works out as the MM Jura range tartan (I randomly chose Black Isle since I have a kilt in that tartan from them) is listed as 331g/sm and 16 oz (actually more like 15.3 oz tartan if you do the math).
    My head hurts. Can I be excused to go find some Advil?
    25th May 06
    Also, some mills dont' specify an exact weight. The House of Edgar's Heavyweight range, for instance, is called 16-17 oz. and their Regimental weight is 17-18 oz.
    Argh... My head hurts too! That's why I didn't want to complicate it!
    John Hart
    3rd January 08
    Illinois, USA
    Thanks for the lesson, it helped to clear a couple of things up for me also. It's interesting that we are having an effect on the weaving industry, and I'd say a good sign that they are open to change and better serving their target audience.
    Member Order of the Dandelion
    14th May 08
    Slovenia
    Quote Originally Posted by ForresterModern View Post
    Isn?t it 28.3g to 1oz ???
  1. 6-yard 13oz versus 5-yard 16oz...
    By CDNSushi in forum Kilt Advice
    Last Post: 13th March 09, 08:10 AM
  2. Traditional 8 yard kilt or 5 yard kilt
    By possingk in forum General Kilt Talk
    Last Post: 17th July 06, 05:53 PM
  3. The Holy mantra of 8 yard tank, 8 yard tank
    Last Post: 25th May 06, 09:16 AM
  4. 4 yard vs 8 yard - Part Two
    By Blu (Ontario) in forum General Kilt Talk
    Last Post: 23rd May 06, 03:35 PM
  5. Whens an 8 yard ,not an 8 yard ?
    By Freelander Sporrano in forum Traditionally Made Kilts and How To Wear Them
    Last Post: 12th October 04, 07:48 PM
