Results 1 to 3 of 3
    25th September 07
    Standish Maine
    Question on tartan fabric weight vs. overall kilt weight
    Just curious - what is the overall weight of a kilt!
    I guess I could find and throw one on a postal scale or could weigh myself with the kilt on and off to compare but I hate to go near the scales!!!!
    The weight of the fabric is per yard correct? Is that based on single or double width?
    If it is based on double width, an 8 yard kilt with 16oz fabric would weigh in total about 4 lbs + (backing and buckles) , right?
    I firmly believe that any man's finest hour, the greatest fulfillment of all that he holds dear, is that moment when he has worked his heart out in a good cause and lies exhausted on the field of battle - victorious! --- Vince Lombardi
    7th July 06
    Roswell, Georgia USA
    Right, Just under 4 pounds because generally the weight is per meter since the material is woven in Scotland and thay are metric.
    The weight of a running yard is still the same - even though the weight and width might be given in metric - so 4 yards of 16 oz tartan, 54inches wide, weighs 4lb.
    Whatever weight of fabric is left after cutting to length, making the waist band and loops, is to be deducted, and the weights of buckles, reinforcing materials, straps, and even a tiny bit for the thread, are added.
    For a fully tailored kilt made for a tall man you could get a finished weight of over 4 lb, even though there would usually be a bit of material left over. For someone really tall you might use every bit of material and add something for the waistband.
    I sometimes use DPM material which has a 'direction' to the pattern, or a pinstripe, where the fabric is cut or torn across from selvage to selvage almost every bit of the material is used. Usually the only leftover is from straightening the edges where it was cut from the bolt.
  1. Weight of fabric vs. style of pleat
    By sydnie7 in forum DIY Showroom
    Last Post: 28th May 08, 10:07 AM
  2. Question about weight
    By arrogcow in forum USA Kilts
    Last Post: 22nd December 06, 04:57 PM
  3. Flashes from light weight fabric
    By Rick in forum How to Accessorize your Kilt
    Last Post: 30th January 06, 03:17 PM
  4. Weight of fabric
    By LordDamax in forum General Kilt Talk
    Last Post: 25th August 05, 08:02 AM
  5. Fabric Weight
    By KiltedBishop in forum USA Kilts
    Last Post: 24th March 05, 04:15 PM
