Results 1 to 10 of 16
    20th February 09
    Fairborn, Ohio
    Sitting in kilts
    There was an other thread about sitting in the kilt and the back of the kilt riding up and either showing or exposing to various surfaces...our dangly bits. I can't find that thread so I'm starting a similar one. I was wondering if the riding up problem has anything to do with the length. Does a 5 yarder ride up more than an 8 yarder? TMI, but I have to do it...I'm sitting in a 5 yard SWK, tucked properly, sitting up straight, and I can still feel the edge of my kilt with...well...you know. Would an 8 yarder actually come half-way down the thigh at least? I want a few contemporary kilts anyways, but I fear that the jeans waist MUG freedom will drive me away from traditional kilting.
    8th May 08
    Jacksonville, FL
    Well, the bigger you are, the more your kilt has to bend around cover when you to sit.
    20th February 09
    Fairborn, Ohio
    This is true. Just one more reason to stay on the treadmill.
    8th May 08
    Jacksonville, FL
    What I've noticed is that the bigger the guy, the shorter the kilt looks. We've got a guy in my band who must have a 28" waist. His kilt looks rather long, but it's the same length, mid-knee.
    Norfolk, England
    There are two things to consider.
    Firstly, is the length of the kilt. 8yarder, 5yarder, traditional, contemporary, if your kilt is too short the problem will be the same.
    Secondly, is the pleat sweep. I tend to sit down at the front edge of a seat and then slide back into the seat. You have got to practice to get it right - for hours if necessary. Till you get it right. Check the tutorials.
    Stand and be counted!
    7th January 09
    Here is a great illustration of how to sweep the pleats:
    http://www.xmarksthescot.com/forum/v...x.html?t=20913
    30th June 06
    Lotusland, Canada
    If you are like me, your MUG is longer than a kilt. My UK hits me about two inches below the knee, that is where they usually hang. It does take some getting used to when you move up to the big leagues but keep on.
    Gentleman of Substance
    pastorsteve's Avatar
    pastorsteve is offline Oop's it seems this member needs to update the email address in their profile.
    25th January 09
    Denver, Colorado USA
    I've never had that problem. I sweep the back when I sit and since it's being sat upon, there's no place for it to "ride up".
    Steve
    Clan Donald
    In the Highlands of Colorado.
    24th June 08
    Widdrington Station, Northumberland, Sassen
    Aye, sweeping is the key, as is sitting slightly forward then pushing back.
    Do it right, and it's graceful.
    Do it wrong and you look like a gay camel sitting down!
    Slainte
    Bruce
    Please have fun reading my blog on my attempt to climb Mt Kilimanjaro in aid of international diabetes research.
    http://www.raven-wilderness.blogspot.com
    8th July 08
    Middle Grove, NY. Just outside Saratoga Springs.
    I used to have the same problem. Key solution is "sit like a girl".....I kid you not. Ifound I was sitting down like I always did in pants; bend over at the waist, sweep the pleats, and plunked my rear into the seat....never worked. Always....ahem...."stuff" touched. I watched the tutorial and discussed offline with a very helpful female member. Her suggestion was brilliant. Instead of bending over at the waist, lower yourself into the seat by bending at the knees, sweep, and when your rear hits the seat slide back into the seat. No more problems.
  1. Sitting down in a kilt
    By bricekolob in forum General Kilt Talk
    Last Post: 15th February 09, 02:27 PM
  2. sitting issues
    By sathor in forum Kilt Advice
    Last Post: 4th October 08, 10:13 PM
  3. So I'm sitting at the pub...
    By beloitpiper in forum Miscellaneous Forum
    Last Post: 29th November 07, 10:21 PM
  4. While sitting
    Last Post: 19th May 05, 09:10 PM
  5. Sitting...
    By Jewddha in forum Kilt Advice
    Last Post: 4th May 05, 04:27 PM
