Results 1 to 10 of 10
    2nd January 11
    Tampa Bay Florida
    Sizing for kilt jacket, re: Length...
    Ok, I am preparing to get myself a kilt jacket and have taken my chest measurement.
    However, all websites specify "short, regular, long" but they have no actual measurement as to what constitutes "short, regular, long". Nor has my google fu described it in detail enough that I understand.
    I'm 6' tall, with quite short legs, long arms, and a long back/torso. However, about half of the "tall" sized shirts I own are perhaps a tad "too" tall.
    Can someone tell me, perhaps an estimate of what measurement constitutes length of the jacket?
    Collar to natural waist (in line with navel) is around 21", outside sleeve to wrist is 23"
    22nd December 10
    Oklahoma City, OK (currently)
    What size jacket would you wear for non-kilted dressing up? I would be a Regular for non-kilt jackets and would be about the same for a kilt jacket. My problem, however, is not the length of the jacket but rather the sleeve length.
    Where are you thinking of getting your jacket? I would call the retailer to discuss if they were one of the suppliers from this forum.
    12th November 10
    Central Kentucky, USA
    Burnett's and Struth give the sleeve lengths of their Lochcarron jackets on their website: http://www.burnetts-struth.com/produ...ay-Jacket.html
    Kenneth Mansfield
    VITAM FORTITER AGERE
    My tartan quilt: Austin, Campbell, Hamilton, MacBean, MacLean, MacRae, Robertson, Sinclair (and counting)
    16th September 09
    Toronto, Canada
    The best thing to do is measure a regular suit jacket that fits you and then compare it to the actual measurements of one that you are considering purchasing. When it comes to off-the-rack clothing, sizing can vary quite a bit.
    That being said, Keltoi also has a sizing chart for kilt jackets here. That should get you in the right ball park:
    http://www.gaelicclothing.com/jacketswaistcoats.htm
    - An t'arm breac dearg
    8th February 11
    Near Thurso Scotland
    It's the sleeve length that counts. Get that right plus chest measurement and the length of the jacket will be decided and will look right.
    Some retailers as I found have five lengths from very short to very long.
    Chris.
    Member of the Clan MacLaren Society.
    Member of The Scottish Tartans Authority.
    Better to be looked over than overlooked. Cock your hat, angles are attitudes.
    M. A. C. Newsome's Avatar
    Contributing Kilt Historian
    26th January 05
    Western NC
    Short, regular, and long refer to the sleeve lengths, not the jacket length itself.
    Basically, "regular" will be the standard sleeve length for the jacket pattern of that particular chest size; "short" will be one inch shorter in the sleeves; "long" will be one inch longer in the sleeves.
    Most places that sell jackets will have some sort of sizing chart on their site for you. For example, we have a table on our jacket page that tells you what the sleeve length will be by jacket size.
    http://giftshop.scottishtartans.org/kilt_jackets.htm
    So, for example, a 44 jacket (which I wear) will have 25" long sleeves (measured from the shoulder seam) for a regular fitting. A long would have 26" long sleeves, and so on.
    If your sizing requirements don't fit the standard mold, you can always go with a made-to-measure option.
    Matthew A. C. Newsome, GTS
    3rd March 10
    43*N 88*W
    If you are of slightly unusual proportion, wish to have a properly fitted jacket, but DON'T have the coin for a made-to-measure; a good tailor is going to be your best friend.
    Buy the jacket that fits best in the shoulders and torso and have the sleeves taken up.
    For years I had the problem that nobody made a suit with a 12" drop (difference between chest and waist measurement), so I'd always be forced to have the side and back seams broken and remade.
    Luckily (sadly) this is a problem I don't have to deal with anymore and can now buy suits with a standard or athletic cut, depending on the maker.
    artificer Pronunciation: \är-ˈti-fə-sər, ˈär-tə-fə-sər\ : noun : 14th century :a skilled or artistic worker or craftsman
    Artificer Custom Sporrans-
    *Home of the Original Kenneth MacLeay Sporran Project & Functional Brass Cantles*
    14th January 08
    Goshen, KY
    There actually are differences in the lengths of the torso portions of jackets as well as the sleeve lenghts as you progress from X-short through short, regular, long, to X-long. I have tried on numerous regular and some long jackets, with the tailor's recommendation that he could lengthen the sleeves to make up for that issue, only to find that the bottom edge of the jackets were way to short as well. Body lengths tend to lengthen as your sleeve lengths do in relative proportion. Since most Argyll style (or variants) kilt jackets have the sleeves at about the same length as or a little shorter than the bottom of the jacket body it would only make sense that, unless you have particularly gorilla-like disproportionaly long arms, sleeve length would also dictate body length in all but specifically made to measure jackets.
    2nd January 11
    Tampa Bay Florida
    Just my luck, I'm 57" at the chest, 45.5" at the waist, and have T-Rex arms.
    I just received my "off the peg" 58R Argyle that fits me PERFECTLY in the shoulders and chest, but has the midsection of a 60" pear and the sleeve length of Tony Robbins. Heck, even the torso length is perfect (I of course put on a kilt and tried it out within minutes of arrival).
    17th December 07
    Staunton, Va
    Quote Originally Posted by Joshua View Post
    A good tailor can nip it in at the waist and you'll look a million bucks in it!
  1. Jacket length advice required
    By chrisupyonder in forum Kilt Advice
    Last Post: 6th March 11, 02:02 PM
  2. UK kilt jacket sizing!??????
    By denmcdough in forum General Kilt Talk
    Last Post: 14th November 10, 03:13 PM
  3. P.C. Jacket and Vest Sizing
    By denmcdough in forum Traditionally Made Kilts and How To Wear Them
    Last Post: 21st December 09, 06:11 PM
  4. Kilt Jacket Length
    By MacBean in forum Traditionally Made Kilts and How To Wear Them
    Last Post: 22nd October 09, 09:27 AM
  5. Kilt Jacket Sizing
    Last Post: 20th July 05, 08:33 AM
