Results 1 to 7 of 7
    Kilts_Knave's Avatar
    Kilts_Knave is offline This registration voided by member's choice.
    17th June 05
    Jacksonville, FL
    Stillwater questions
    I want to get a Black Watch heavyweight from Stillwater but 24" is way too long on me. (I have very stumpy legs!).
    Question 1: Has anyone here shortened one and how did you do it?
    The Website tells me "these kilts can be easily shortened by the purchaser if needed."
    Question 2: How is it possible to maintain the proper shelvedge?
    [B]"Life is not always a matter of holding good cards but playing a poor hand well"[/B] [indent]~ [I]att. to Jack London[/I][B][I][/indent][indent]Visit me at
    bubba's Avatar
    14th February 04
    Little Chute, Wisconsin
    You hem it up. The Stillwaters are still light enough that they can be hemmed and once properly pressed look good.
    23rd January 04
    Philadelphia
    Bubba's right. The StillWater acryllic is pretty easy to work with, and any tailor or seamstress can do the job if you can't. It's as simple as hemming it up to your preferred length. Just be careful with the taper and fringe on the apron. You'll need to release the the side hem before you do the bottom hem. After it's complete, THEN you can rebuild the tapered apron.
    Pressing is easy since they're not using the wool material yet. It's VERY sharp and crisp when pressed correctly. Don't overheat it with one pressing. Rather, use a lower setting, and press BOTH sides a few times. It will hold the pleats better too.
    For the customer service, speed, product, look and price... you just can't beat the StillWater Kilts. They're not a custom fit, but with a little work... they can be.
    Cawdorian's Avatar
    Cawdorian is offline This member has been inactive for more than 1 year
    17th July 05
    Alpharetta, Georgia USA
    10 oz wool kilts are hemmed, I understand the 10 oz material doesn't come with a selvedge.
    Jim
    24th July 05
    Narberth, PA
    Quote Originally Posted by Jimmy Carbomb
    Jimmy
    The SWHW BlackWatch is wool. And per Jerry the Black HW acryllic is being phased out and they are coming out with a wool one next month with better buckles.
    I'm not crazy, I'm just running.
    http://www.kiltedrunner.blogspot.com/
    bubba's Avatar
    14th February 04
    As I understand it, the Stillwater heavyweight in wool is approximately 13 oz, which is still in the range to be hemmed.
    17th June 05
    Jacksonville, FL
    Quote Originally Posted by millar
    [T]hey are coming out with a wool one next month with better buckles.
    Hopefully they will have one in 34" --there seems to be a shortage of them...
