Results 1 to 6 of 6
    21st October 21
    Memphis,Tn,USA
    Tailoring an argyle jacket.
    I was wondering if it was possible to have the sleeve with a gauntlet cuff of an argyle jacket shortened without ruining the jacket? Let’s say I found a jacket on eBay or somewhere similar but the sleeves were too long. How would I go about it? I probably wouldn’t be doing it, but a local tailor.
    “Never wear anything that panics the cat.”- P.J. O’Rourke
    “People will stare. Make it worth their while.”-Harry Winston
    30th September 08
    Cypress, Texas
    While lI don’t know the particulars of how it’s done, I’ve had the sleeves shortened on several eBay-purchased gauntlet cuffed Argyll jackets by a local alteration shop. I can’t imagine it would be a challenge for an experienced tailor or seamstress.
    Take the jacket to the shop and they’ll have you try it on and will mark up the sleeves with chalk and/or pin them up to your satisfaction, then will make the alterations required. It shouldn’t take too long or cost too much (at least in my experience).
    SM
    Shaun Maxwell
    Clan Maxwell Society
  3. The Following User Says 'Aye' to ShaunMaxwell For This Useful Post:
    7th February 11
    London, Canada
    I am absolutely no tailor, but I think a good tailor might even remove the sleeve and shorten it at the shoulder. I've been surprised by some of the ways my fellow has successfully made a variety of adjustments.
    Rev'd Father Bill White: Retired Parish Priest & Elementary Headmaster, lover of God, people (most of them!) dogs, joy, humour & clarity. Legion Padre, theologian, teacher, philosopher, linguist, traditionalist, bon-vivant, encourager of hearts & souls & a firm believer in dignity, decency, & duty. A proud Canadian Sinclair.
  5. The Following User Says 'Aye' to Father Bill For This Useful Post:
  6. #4
    I think it depends on how your arm fits into the sleeve shape - over the years I have recut sleeve caps to keep most of the sleeve as it was, shortened the cuff and removed a piece from behind it as the sleeve was long below the elbow and the cuff made in proportion, or cut the cuff off and shortened the sleeve then reattached the unaltered cuff. The last one was the most difficult as it was a mass produced jacket.
    Tailor made garments with some age seem to be the easiest garments to alter. Some modern garments are impossible to work on as the seam structure is all that is keeping the threads together.
  7. The Following User Says 'Aye' to Pleater For This Useful Post:
  8. #5
    15 Post(s)
    I think a lot depends on how the cuffs are made.
    Here are three Argyll jackets, the left and middle ones have a false cuff sewn all around onto the sleeve prior to the back seam of the sleeve being sewn. I suppose it would be possible to completely remove the cuff and move it higher. But not knowing if there's fabric underneath the cuff, or if it's possible to remove the cuff cleanly, I couldn't say whether it would be possible to lengthen the sleeve.
    The jacket on the right has the cuff as a separate piece, thus it would be simple to move the cuff higher or lower on the sleeve.
    Here you can see that the cuff is lined in satin like the rest of the jacket.
  9. The Following 4 Users say 'Aye' to OC Richard For This Useful Post:
  10. #6
    26th December 20
    Chicago, IL
    I had two jackets with gauntlet cuffs shortened in exactly this way. Turned out beautifully.
  11. The Following User Says 'Aye' to ktk1961 For This Useful Post:
