30th June 11, 05:47 AM
Tailors! Kilt makers! Help!
I have two wool 13 oz hand sewn 8 yarders that I love. Problem is they only have two straps and I have no rear. Even fitting at their best they slide a little. Would anyone be willing to do a little work on them to add some hip straps? Is this possible?
Please help,
Hugh
God bless the kilted everywhere and all who see them!
The kilt! It gets in your blood and cannae be removed through medicine or magic.
30th June 11, 05:55 AM
If you have no hips, adding a hip strap will not really cause the kilt to sit any better. The only thing you can realistically do (IMHO) is:
1. Make sure the waist straps are SNUG and wear a shirt that is not 'slick' (like silk or rayon). Sometimes wearing a shirt where the material kind of 'grips' the lining in a kilt may help it stay up a little bit.
2. Get yourself a pair of braces (suspenders).
3. If you're not wearing a kilt belt (again, SNUG), wearing one may help.
4. Wear lighter weight kilts (ordering a 6 yarder). Less weight makes it a little less likely to fall down.
30th June 11, 06:24 AM
I have another kilt that is heavier and it never moves. The only difference in make that I can see is no hip strap. I wear no kilt belt with the three strap, works fine. I wear a belt with the two strap, still a little slide. The waist on the one two strapper is tight as it could be and still allow breathing.
30th June 11, 06:29 AM
BM, can we trade bodies?
30th June 11, 06:51 AM
Nope. I've worked to hard on this one.
Hugh
30th June 11, 07:21 AM
I added suspenders, and rather like them at "slidy" times. A vest over the suspenders keeps them less obvious. I don't actually have the same problem you describe (my butt is plenty big!) but there are times to use this technique well.
Rev'd Father Bill White
Priest, Lover of God and People, Theologian, Student, Teacher, Philosopher, Dreamer, Humourist, Encourager of Hearts and Souls and a firm believer in the value of Dignity, Decency, and Duty.
30th June 11, 11:27 AM
I can just see it now a new fashion... Steeped in history... Ressurected for the future...
30th June 11, 11:57 AM
One reason a kilt may slip is that the smallest part of the kilt may not be at the level of the straps.
This means that no matter how tight you cinch the straps the kilt will always try to move so the smallest part of the kilt is at the smallest part of your body.
Here is a shot of a well made kilt folded in half.
You can see that the smallest part of the kilt is at the level of the top straps. The Fell tapers in, up to the height of the strap and then flares back out above the strap.
If your kilt does not flare back out above the straps it will always slip. Adding additional straps will not correct this problem.
www.Freedomkilts.com
2nd Laird of Lochaber
By longhuntr74 in forum DIY Kilt and Accessories Help
Last Post: 2nd May 11, 08:59 AM
By gunni in forum General Kilt Talk
Last Post: 9th February 09, 07:14 PM
By setboy in forum General Kilt Talk
Last Post: 14th October 06, 05:16 AM
By jjoseph in forum General Kilt Talk
Last Post: 12th May 06, 01:27 PM
By RockyR in forum Professional Kiltmakers Hints and Tips
Last Post: 20th October 04, 02:18 PM
