21st January 09, 11:47 AM
Tux coat for kilt
http://tuxedowholesaler.com/product_...-9FFF62E7FCDF}The only used tux I can find in my size is this one Is the style to far off?
MM
21st January 09, 11:51 AM
An Eisenhower-length jacket should be just fine w. a kilt. Looks like a good find to me!
21st January 09, 12:18 PM
I'd agree. The main reason why a standard length tuxedo coat doesn't look right on a kilt, is because of it's length. The waist length coat would probably look very good. Good find!
21st January 09, 12:24 PM
Bravo Zulu!
"the power of Google is strong in this one!"
Very good find!
< as he nonchalantly bookmarks the page for himself... >
Hello nurse! Is it time for more meds already? Well, alright, but I'm just in the middle of posting... Ouch! Hey... Ohh!... I... feel... much... calmer... already...
21st January 09, 12:25 PM
So I can look for an Eisenhower length jacket.... instead of a PC, interesting.... Now I have something to look for I guess.
I might need to go downtown to the formal store and see if I can get one from them....
21st January 09, 01:20 PM
Do a lot of photo comparison before buying a tux jacket that is so different from a PC. Envision the jacket you are looking at in place of the PC and see what you think. It would be a shame to buy the coat and put a bunch of effort into converting it and then find it just doesn't look like you hoped.
Another place to look is http://www.uniformalwearhouse.com/ap...ojackets4.html
The key to using an Eton jacket or any other sort of PC alternative is not to try and make it look like a PC jacket. These jackets can be made suitable for formal events where others may be in PC jackets but if you were to stand beside them it will be very obvious that "one of these things is not like the other". I'm not saying that's a bad thing, I have a modified Eton jacket that works very well at formal functions. I would avoid putting epaulets and gauntlet cuffs on it.
The double breasted nature of this coat AND the V-neck collar will be tough to work with in my opinion.
It would be safe to replace the cloth covered buttons with pewter or nickle buttons. Use the search function for pewter buttons and you will find several vendors. I used the Eagle buttons from Three Feathers.
Again, I'm not trying to discourage you from converting a jacket just avoid the impulse purchase and take the time to find the right jacket that will present the image you want.
21st January 09, 01:36 PM
I would refrain from doing much of anything with this jacket, with the possible exception of replacing the buttons, per Cavscot's suggestion:
To reiterate, I think this jacket would be spot-on for kilted black tie without the need for any embellishment, conversion, etc.
Cavscout -- I don't believe MuffinMan's intent was to convert this to a PC, rather to wear the jacket "as is" for kilted black tie....
21st January 09, 01:38 PM
I would discourage you from buying that jacket-- I've seen one worn with the kilt and it looked just awful. The worst part was the satin waist band-- it sends shivers down my spine just thinking about it. Unless you are buying a Montrose doublet, you really need to stick with a single breasted jacket; double breasted jackets just don't work. I'd suggest you shop around for an Eaton jacket, otherwise keep looking for that elusive tailcoat in your size.
21st January 09, 01:49 PM
This Jacket Is Like A Mail Order Bride
that should include buying it.
Guys, it only closes (buttons) on the bottom button, and it has a mega tendency to ride up over the back of the kilt while the front gaps open like Alfred E. Newman's buck teeth. If you are built like a flamenco dancer (tall and thin with no butt) it would look good with trousers/trews. But if you are anything but a size 38 Long, it will look awkward at best.
I've seen it worn by a thick set fellow in a kilt, and it looked dreadful. Just like the mail order bride he got off another website. Just plain ugly.
21st January 09, 01:51 PM
By The Wizard of BC in forum Freedom Kilts
Last Post: 30th October 07, 01:11 AM
By Kiltedmusiclover in forum Kilt Advice
Last Post: 12th August 06, 01:51 AM
By Eujeankilt in forum How to Accessorize your Kilt
Last Post: 5th December 05, 08:34 AM
Last Post: 23rd November 05, 09:37 AM
Last Post: 24th January 05, 11:40 AM
