28th April 10, 01:21 PM
Bagpipe chanter
I really want to get rid of my Poly chanter.
What is your favourite pipe chanter? And why?
29th April 10, 10:17 AM
29th April 10, 12:58 PM
I use a Naill blackwood and an old robertson from about the 30's although McCallum makes some nice pc's as well.
29th April 10, 02:52 PM
For personal performances, I play a Naill blackwood with a McPhee reed. It's got good tone and balances well with the drones (Crisler rosewoods w/ Kinnaird reeds). It also required very little tape to tune (just a little on the F).
For band, I think it's a McCallum Mark I (poly) w/ a Warnock broad. A little bolder/brassier tone (for band purposes it works well).
John
29th April 10, 11:02 PM
So far, so good. Every one prefers different chanters.
My band plays Shepherd Poly chanter, but I really want a blackwood chanter for when I am playing solo. It is just that I am a bit new to bagpipes, and my PM says a blackwood is a bad idea since it breaks too easy. Hence I turn to you guys to raise my knowledge about what I would expect to like when I try different chanters in the summer.
30th April 10, 09:26 AM
I agree that for band purposes, an ABW (African BlackWood) chanter is a bad idea. Too many opportunities for breakage. (For example, people pulling/pushing/turning the chanter at someplace other than the reed seat. The narrowest part of the chanter is very fragile regardless of the material and the chanter shouldn't be manipulated in the stock anywhere but the reed seat). Plus, from a moisture standpoint ABW is less stable, therefore it's harder to get a bunch of ABW chanters to tune together.
I don't carry my Naill with me most of the time (I don't do solo gigs very often, as I'm still a novice piper), just to keep it safe. In fact, the only time it leaves the house is for gigs and/or the occasional private lesson.
John
30th April 10, 11:57 AM
I agree with using poly for bands are ok, but I would love to have a good balckwood chanter for solo. I started on the practice chanter a year ago, but already have weddings and partys to pipe solo. Would be great to get that beautiful sound that I some times hear.
I know it's a lot of technique, but I did compare my blackwood practice chanter with a poly one. That was a huge difference in the comfort of playing!
I'm unclear whether the discussion is about practice chanters or actual GHB chanters, so I'm going to give my opinions about both.
With PCs, the important thing is that you practice on them. If the blackwood will make your practice more enjoyable, then use blackwood. I prefer it personally because my old Hardie blackwood PC (with lurid yellow sole) sounds better than any of the plastic chanters I have tried so far. But I've only tried about 4 different makes of plastic chanters. I found that the Hardie was what I wanted and I play it with pleasure so I play perhaps a bit more than I would with a less pleasant instrument.
With GHB chanters, I see plastic as having a place in a band or when you have some reason to want a fairly bulletproof chanter. That's about it, though. I'm a rather opinionated cuss about my chanter.
I play a McCallum blackwood chanter (round holes) and I love it. I do own a couple of other blackwood chanters, most notably a Hardie that will give me a true Bb with reeds I can get today. (Some older chanters can be hard to fit a reed to, it seems.) I do have three plastic chanters (one is for band, one is for a beater pipe and the last is my Dunbar plastic chanter that goes with my P1s that I loaned to a good friend) and I have experience with a couple of others. While the sound can be very good on all of them, I find that there's a strident edge to all of my plastic chanters that is not there with wood. It is subtle, but consistent across the board so I believe is a part of plastic chanters in general.
My personal contention is that my blackwood chanter makes me a better piper. It is more vibrant and lively than plastic. The tone is richer and mellower. Not hugely, but all these little things add up. Ultimately, I take greater pleasure in playing a blackwood chanter so I play it more. Just that simple. I will play what I like to play.
Very few people are going to play the pipes without loving the music. If a particular setup makes the music better for you, then go with it. Play it and love it. Play the setup that makes you love it more. I had this brought home to me yet again yesterday. I played my personal music for about 40 minutes out on my deck, saving my energy for band practice. Then I spent nearly 2 hours playing at band. At home I was using a chanter and reed that I really like. At band, it was the band poly chanter and the band reed. The chanter felt dead and unresponsive at band. The reed was harder (ever so important to band sound that we all play reeds that are like blowing on a 2x4 because some yahoo from a big-name band said that's the way to get tone) and kept cutting out on me as I got worn out. At home, I was wanting to play for a long time. At band, I couldn't wait for it to be over. Just because the chanter and reed combo is so different.
Seek a chanter and reed that make you want to play. The more you play, the better you get.
-Patrick
Oh, and regarding breakage, I say hogwash.
Yes, a blackwood chanter will break more easily than plastic. But plastic can be broken. And blackwood can last a hundred years with basic care. Just treat it right (you should have been taught how to treat it when you learned to play - never grip it in the middle or bottom to rotate it or remove it, only at the knob by the stock, also wrap it in a towel when you put it away, that kind of stuff) and you will be using a blackwood chanter for your entire piping life.
I am apparently in the minority in that I feel every beginning piper who intends to play for any length of time should start with a blackwood chanter. Pay for the upgrade when you buy the pipes. If you play with a band, they will issue you a band chanter. Probably poly. But for your playing at home and on tunes you love, use the nice chanter. And treat it right.
-Patrick
18th May 10, 03:03 AM
Thank you very much! It is the GHB pipe chanter I really want. Since there is so many brands, makers, oppinions; I get confused.
When I started playing a year ago I went straight away and bought a hardie BW practice chanter with som engraving on it. It costed a bit extra, but was worth it. The first thing it that if you like your instrument, you want to play it more. And then you will also treat it better. I have later on tried the poly PC that the others use, but cant really find the joy with them. Poly is so cold and dead with a sharp sound. The BW gives a more feel to the playing and I feel that techniques go better on it.
The problem is the pipe chanter. The poly I have is rubbish. OK for a beginner, but I can't play any faster tunes on it than mabe 6/8 marches. It squeeks when changing notes fast, and gives a sharp sound. It does OK for slow tunes, but still sounds a bit noisy. The sound I am looking for is something that is pleasent to listen to. I want people to lean back and enjoy, not cover their ears.
About breaking ... I can't really see that I will be breaking it. For any good instrument I have I do take good care. It's just a matter of keeping it in a solid case when not playing it. The only way I think it could break might be if it is treaten the way some people treat their pipes. (lay it on the ground when playing outside. After practice; just throw the pipes in a backpack and head off to the bus. Don't take the pipes up from the backpack till next practice. etc..etc..) People have been playing BW chanters for a very long time, and they could take care of them. So whay can't we take care of it as well?
By ChromeScholar in forum Celtic Musicians
Last Post: 31st January 09, 07:42 PM
By Nighthawk in forum Celtic Musicians
Last Post: 12th August 08, 03:36 PM
By JayFilomena in forum General Celtic Music Talk
Last Post: 3rd March 08, 09:37 PM
By porrick in forum Miscellaneous Forum
Last Post: 13th April 06, 12:36 PM
By Phil Wright in forum General Celtic Music Talk
Last Post: 19th August 05, 05:03 PM
