3rd September 19, 09:00 AM
Ahh, ok that makes sense. I felt my side again, and you're right, the place where I bent was indeed where I felt bone. So let me rephrase my question then. Regardless of what each kiltmaker asks for, where should a kilt sit? Is there a difference between an everyday kilt or a kilt as worn in the military or in a pipe band? I ask as I have one kilt where the kiltmaker used my navel to mark the top, and it sits lower than any of my band kilts.
3rd September 19, 09:35 AM
The Following 3 Users say 'Aye' to The Wizard of BC For This Useful Post:
4th September 19, 04:02 PM
Thank you for all of that. Really interesting to see all of those pictures with explanations as to what's actually not working well. The kilts I have all sit nicely; it was just a matter of length. I actually prefer the kilts that sit a little higher at the anatomical waist. That also seems to jive with what I'm seeing in the pipe bands here so I'll go with that and wear it with pride.
4th September 19, 06:03 PM
The bottom line is to measure your body
Regardless of what someone else wears, or where you measure from, the key is to measure your own body and use that measurement. Some people are the same length from their waist up and the waist down. Others have longer legs than torsos. Others have longer torsos than legs. So, a dozen people who are the same height as you could all have different length measurements for their kilts. So, measure your body and use that number.
The hielan' man he wears the kilt, even when it's snowin';
He kens na where the wind comes frae, But he kens fine where its goin'.
4th September 19, 06:07 PM
#15
4th September 19, 06:10 PM
#16
I'm 5'11 1/2". My first purchase from USA Kilts was 24". I like my kilts to sit at the anatomical waist. However, once I start dancing, they tend to migrate down slightly. Therefore, for my second USA Kilts purchase, I got a 23.5" kilt. That works much better (for me) when I'm highly active.
Given that you're noticeably taller than me, and you like to wear your kilts a little higher than I do, I think 24" would probably be a minimum (unless your thighs are shorter than mine).
Trying to look good on a budget.
