Results 1 to 10 of 16
    2nd January 10
    Crieff, Perthshire
    14 Post(s)
    A bit of elbow grease
    Amazing what half an hour of work with some silver polish will do.
    Reminds me of doing that myself, probably have to do it again. Here was my result
  3. The Following 5 Users say 'Aye' to McMurdo For This Useful Post:
    22nd October 17
    Beijing
    7 Post(s)
    Gentlemen,
    Both of these sporrans look fantastic. Great work!
    Andrew
  5. The Following User Says 'Aye' to kingandrew For This Useful Post:
  6. #4
    5th May 20
    Aberdeenshire
    I don't know what you were using, but be careful of repetitive use of liquid/gel polishes, particularly on an engraved piece, over time you will loose much of the sharpness. My two preferred methods for polishing engraved silver are the "town talk" anti-tarnish silver polishing cloth (no affiliation) or some rouge on swans-down cotton cloth. Normal rouge is wax based, so if you get it on the pelt it could be a nuisance to remove so be careful, powdered rouge is also available, you can mix it into a paste with water and any overspill will wash off easily. However, it's much more messy to work with in the first instance.
  7. #5
    24th January 20
    Near Grand Rapids, MI, USA
    I've seen some good things done with putting silver into a bath of dilute lemon juice (or any ionic solution, like salt water) and aluminum foil. From what I understand of the chemistry, it strips off the oxygen atoms from the tarnished silver and deposits it onto the aluminum. It supposedly is a near perfect reversal of the silver tarnishing process, in a way that can't be done with structurally-damaging volume-expanding oxides like rust. Do some research yourself - I'm no expert - but it might be worth a try for buttons or if you can remove the cantle from the sporran.
  8. #6
    30th September 08
    Cypress, Texas
    Quote Originally Posted by MichiganKyle View Post
    I used a similar method to clean a sterling cantle I'd removed from a rather moth-eaten sealskin sporran, with great effect. I put a sheet of foil (shiny side up) in a glass baking dish deep enough to cover the cantle when filled with water. I liberally sprinkled the cantle/pieces with baking soda, then poured boiling water over it — enough to submerge the cantle/pieces. It produces a bit of a reaction. I repeated the process a couple of times and had a good result:
    SM
    Shaun Maxwell
    Clan Maxwell Society
  9. The Following 6 Users say 'Aye' to ShaunMaxwell For This Useful Post:
  10. #7
    24th January 20
    Beautiful! That process is supposed to be entirely nondestructive and safe to use as many times as necessary, as far as I understand it.
  11. #8
    7th May 20
    Ayrshire Scotland
    Sporran Cantle
    I'm looking for a cantle for a pheasant sporran but I'm struggling to find anything online. Can anyone recommend where I can find something?
    Many thanks
    Michael
    Ayrshire, Scotland
  12. #9
    17th December 14
    Windsor, ON, Canada
    Have you seen these?
    Quote Originally Posted by M A N N A View Post
    Many thanks
    Michael
    Ayrshire, Scotland
    There is one on Esty for a good price.
  13. #10
    6th November 08
    Clanart pewter has Cantles and the quality quite good.
    http://www.clanart.net/
    Being male is a matter of birth,
    Being a man is a matter of maturity,
    Being a gentleman is a matter of choice!
