15th February 06, 06:24 PM
Epoxy Or something Else
I've got several embroiderd patches and instead sewing them on I've put pins on the backs. I used two part epoxy on them and was wondering:
A. How well it holds metal to cloth.It seems to be holding nicely.
B. Are there any alternatives that work as well if not better.
Any and all tips, suggestions etc. are appreciated.
15th February 06, 06:55 PM
It may work OK as long as you don't put the item in the wash. If there was a way to sew the items together, that might be more secure. As an alternate to epoxy, Gorilla Glue might be a worthy option. PVA glues are too soluable.
15th February 06, 10:23 PM
There is an epoxy I used to use in concrete work that bonded to cloth really well. If you dripped any on your pants it would set in the material and would tear little holes in the cloth if you tried to remove it. The only other way was to beat it with a hammer when it was fully hardened and let it crack into little chips that could be picked off.
15th February 06, 11:54 PM
I was doing a LOT of patches on my Utilikilt pockets...just ironed them on...since have taken some off...in fact most...I change, what I want on the kilt changes...would reccomend just sewing them on in case you change your mind...get it that you're using pins...can't see how that would work well with the changing shape of the kilts...
Hey, what do I know...?
Ron
16th February 06, 05:11 AM
If you are looking for really good adhesion, try RayCrete(www.raycrete.com) or J-B Weld (http://www.jbweld.net/index.php)
Either of these is far better than standard two part epoxy.
16th February 06, 06:00 AM
I agree with Ron, sew them on (hey, that rhymes).
you can undo the threads when you want a change. Embroidery seems to be made to attach to cloth, not metal IMHO
16th February 06, 09:13 AM
I sense a little confusion. I'm not gluing them directly to the kilt. Instead I put a pin on the back so they could be worn like a brooch,clan badge etc. As soon as I get a new camera I'll post some pics.
16th February 06, 09:56 AM
Instead of gluing the pin to the patch, get yourself some stiff felt. Not sure the technical name for it, but it comes in one sq.ft pieces at just about any craft store. Then sew the pin(s) to the felt, cut to size and sew the whole thing onto the patch. Besides stiffening the patch, it provides a tad more more.
16th February 06, 10:19 AM
Here's what I did- I found some of the Dritze denim repair patches (iron on type). I used these because they're stiff and will reinforce the patch.The patches didn't have the iron on adhesive on the back so these work. I applied the repair patch to the back,trimmed it and epoxied a pin on. I'm wondering how well the epoxy will hold the metal pin on the cloth.
16th February 06, 10:22 AM
