Results 1 to 7 of 7
    29th September 12
    NH
    Sporran strap width?
    A minor point, to be sure, but is there a consensus on the correct width for a plain leather sporran strap for day wear? Commercially available straps seem to be in the 1/2" - 3/4" range. I've used a 1" dress belt as a sporran strap and was wondering if I was comitting an offense against tradition and/or good taste.
    I have two - a black and a brown. Both are 1" wide.
    1st August 11
    Romsey Nr Southampton UK
    Absolutely no offence committed. I think mine are 3/4 inch, but no reason that they can't be an inch. Whatever keeps your sporran up.
    Best regards
    Simon
    5th April 13
    Howell, Michigan
    If I recall correctly, you want to be careful of using a </unmentionable> belt. Some belts use some sort of "synthetic goo" to round the outside edge. This can rub off and do nasty things to your kilt. As for the width? I think as long as it fits the loop in the back of your sporran and it looks okay to you in the mirror, then your good.
    Someone with a better memory will probably add the missing details. I'm sorry about the imprecise description but it's Friday and ... oooh look, shiny....
    6th February 10
    U.S.
    Quote Originally Posted by Grizzly View Post
    Right! I always go with 3/4" and my sporran straps are bespoke from McRostie's of Glasgow. However, since McRostie's items are indeed bespoke, they can make a sporran strap of any width and length.
    9th April 13
    Gilbert, Arizona
    I took a 1 1/4" belt and notched it down to 5/8", looks and works awesome.
    15th March 06
    Kalamazoo, Michigan
    Sometime back I ordered a 5/8 inch all leather sporran strap with trigger snaps to replace the standard chain belt. I got this from a former member of the forum, but I'm not sure he is still in business. I have now made myself a 3/4 inch all leather strap with trigger snaps and I like this width much better. More substantial and comfortable than the 5/8 inch width. Just personal opinion, but a 1 inch belt would be too wide for my taste, unless you have a really large sporran! On an interim basis though, a commercial belt could work, but as Kiltedrennie mentions, be careful that the dye or finish doesn't rub off on your kilt especially if it gets wet!
    Here is a picture of my current strap:
