Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    24th September 04
    When stitching pleats - due to the way I support the weight of the kilt on a table in front of me because I stitch left-handed - I always stitch in the direction from the hips to the waist. This allows me to control the tension on the fabric with my right hand and the needle in my left.
    I also press my pleats before sewing and use pins as I work.
    Barb likes a leather thimble. I prefer a British style ring thimble and learned to hold my needle like a British Tailor.
    Forum Owner
  2. The Following User Says 'Aye' to Steve Ashton For This Useful Post:
  3. #12
    6th October 23
    New Jersey
    I've never been able to work with a thimble, but may have to give the ring thimble a try. Never seen one before! I have a huge callous on the side of my middle finger that acts as my thimble, lol.
  4. #13
    24th September 04
    I use a total of only four stitches to make a kilt.
    The Fell Stitch as described earlier.
    The Pad Stitch also described earlier.
    The Catch Stitch to sew up the small corners of the aprons at the selvedge, the inside of the apron facings etc.
    The Pick Stitch for apron facings, liner and anywhere else I don't want stitches to show on the outside of the kilt.
    Forum Owner
  5. #14
    24th September 04
    When hand-stitching a kilt I am not inventing anything new. I use the same techniques, methods and materials as a Saville Row Tailor. Just not as skillfully.
    There are very few places where kiltmaking and making a man's tailored suit vary. In a kilt there is a line of stitches to support the weight of the pleats where they are cut away and would sag by gravity if not supported.
    When making a kilt there is no paper pattern or cut out pieces that are seamed together. In fact, right up to the point where the inside of the pleats are cut-away to prevent bulk in the back of the Fell, the entire kilt can be un-stitched and will be a long, single length of fabric again.
    Things like interfacing which give stability, body, and prevent drooping are the same. Only when stitching the straps and buckles do I stitch all the way through the outer Tartan fabric and interfacing to anchor the straps and buckles to the stabilizer with strong upolstery thread.
    The liner on the inside of the kilt is only there to hide the internal strengthening elements. It is usually made from a cotton boadcloth and can be replaced if needed without needing to disassemble the kilt. the liner should be fully sewn on all the edges. There should be nothing to catch or snag inside the kilt.
    In fact, one of the dead give-aways that a kilt is not made to be of heritage quality is when you can lift the liner, find any interfacing sewn to just the liner, an and the pleat cut-aways allowed to fray.
    Forum Owner
  6. #15
    23rd July 21
    Randers, Denmark
    Now here's a whole goldmine of informations!
    Thank You very much Steve! This is really worth learning from...
  7. #16
    24th September 04
    Quote Originally Posted by Naught View Post
    Does it not matter that the fell stitch is only catching two layers of fabric - those visible in your first photo - since the stitches aren't, or shouldn't be, under tension? I don't seem to be able to catch the bottom (unseen) layer without taking a stitch that is 3/16" or more. The idea in the post above yours of using a curved suture needle is interesting, though having never sewn with one it would probably be too weird to me.
    The second or bottom layer of fabric does not need to be caught by the Fell stitching. You need that second layer to sort of float inside the kilt. That is the part that you cut-away inside.
    Forum Owner
  8. The Following User Says 'Aye' to Steve Ashton For This Useful Post:
  9. #17
    You don't have to pull the stitch tight as you sew - you can leave some slack if it helps you get to the underside of the fold being fixed down, so maybe half a dozen stitches and then draw in the first three or four using fingers and then the tip of the needle so they vanish under the fold.
    Anne the Pleater
  10. #18
    24th September 04
    I use a slightly different method than Anne. I try to get the tension on each stitch as close to the same as I am capable. I am more concerned with even stitch tension than I am with tight stitches.
    There is no "Right". There is no "Wrong". There is only what works for you!
    Forum Owner
