Results 1 to 7 of 7
    28th February 07
    Minneapolis MN USA
    Looking for buttons
    I'm looking for, I'm guessing they are supposed to be dyed horn buttons like you see on some of the nicer Crail jackets,
    My wife is doing a conversion on a charcoal tweed sport coat for me.
    Thanks in advance!
    Commissioner of Clan Strachan, Central United States.
    16th May 08
    forgotten
    If you see abbreviations, initials or acronyms you do not know the Xmarks FAQ section on abbreviations may help.
    www.xmarksthescot.com/forum/faq.php?faq=xmarks_faq#faq_faq_abbr
    I wear the kilt because:
    Swish + Swagger = Swoon.
    Traditionaly the buttons,on a tweed Argyll, would and are still made out of red deer antler.I suppose some sort of hollow drill cuts them out.You chaps are not short of the odd antler over there, why not make your own?My tweed Argyll and waistcoat have buttons cut from the antlers of my eldest son's first stag.
    15th July 07
    California
    I did this on one of my jacket conversions. It was really quite easy, once I located a friend with the right tools.
    I needed a band saw and belt sander. I used the band saw to saw little round slices from anltler ends and the slightly rounded the corners with the belt sander. I took them home and drilled two small holes for thread.
    Once the tools were located, it took about a half hour.
    29th January 06
    Asheville, NC
    Quote Originally Posted by James MacMillan View Post
    I'd use my band saw for this, too, but you can get by with hand tools. A fine-toothed coping saw and a small bastard-cut file and then 150-grit paper will do the job. Will take a bit of time, but you're only making a few. Don't forget to ease the edges of the drilled holes so that the antler doesn't cut your thread.
    You've got a bodacious deer herd up there in MN, eh? Should be no problem locating a source for antlers. This time of year you can even find your own shed antlers in the woods if you look around a bit.
    28th February 07
    Minneapolis MN USA
    Thank you very much!
  1. Between the buttons, which way is up?
    By gilmore in forum How to Accessorize your Kilt
    Last Post: 8th February 07, 11:47 AM
  2. Pewter buttons
    Last Post: 25th October 06, 01:48 PM
  3. Jacket Buttons
    By ckelly327 in forum Kilt Advice
    Last Post: 29th June 06, 12:27 PM
  4. How many buttons?
    By mbhandy in forum Kilt Advice
    Last Post: 25th April 06, 07:14 PM
