Results 1 to 10 of 10
    30th August 10
    Cedar Rapids, Iowa
    Question Fashion etiquette
    Is it proper or permissible to mix silver and gold colored adornments when wearing formal dress attire? i.e. silver sporran fittings and jacket buttons with gold belt buckle and kilt pin?
    I would try and avoid mixing metals, but you can only wear what you have. Sometimes it is unavoidable. If you are one of a great many kilties at the event, then eyebrows might get raised. If you are the only kiltie then you are the expert and no one will question it.
    Generally speaking I think it is better not to mix metals. Although, I think a gold watch chain worn with sliver buttons will not raise an eyebrow. I have seen very small gold(real gold) buttons worn on a waist coat whilst the jacket had silver(real) buttons and very effective it is. Frankly in the assorted lighting effects of a dress occasion, who is going to really notice and who is going to comment if they do?
    3rd March 10
    43*N 88*W
    PLUS, if it's REAL metal (gold/silver), you've got nothing to worry about. If the fashion police come around you simply say... "It's real gold" and they tend to shut up.
    ith:
    Kerrville, Texas
    8 Post(s)
    What's this, then? Jock is talking about MATCHING?!
    I won't pretend to speak as an expert on formal kilted attire, but in general, I don't give a hoot whether my metals match or not. I always wear my wedding ring which has both silver and gold. And I always wear my class ring from college (Texas A&M University), which is gold. So I'm already mixing metals just with the rings I wear. Seems pointless to worry about trying to match everything else when these don't match.
    The trick is, if you're going to mix metals, do it throughout. Don't wear 90% gold and 10% silver. The silver will stick out like a sore thumb. But if you wear both silver and gold accessories, evenly distributed about your person, it can work. Especially if some of your accessories are made from both silver and gold in the same piece.
    30th June 10
    San Francisco, CA, USA
    I'd agree with that.
    18th September 08
    Northern Virginia
    I recently started looking for silver studs for my shirt. I have a gold set but thought they looked odd when worn with silver button on the jacket, a silver belt plate, silver cantled sporran, and silver cuff-links.
    US Marine (1970-1999)
    17th December 07
    Staunton, Va
    Quote Originally Posted by jimusic View Post
    Generally speaking, if you are formally attired you will be wearing a jacket and waistcoat with your kilt. In that instance a belt would not be worn unless you are also wearing a dirk, in which case the belt would go over the waistcoat. (The exception would be a Montrose doublet, or similar, where a belt is always worn.)
    If, for whatever reason, you choose to forgo the waistcoat, then, for the sake of uniformity, the buckle should match your buttons. The kilt pin is an entirely different matter, and may be gold, silver, or any other sort of finish one desires.
    13th March 05
    I mix metals. My wedding ring is white and yellow gold. I wear gold and silver rings, and my kilt pins are all silver or pewter. My pocket watch is gold. I like the look of mixed metals, but that's just me.
    17th December 07
    Staunton, Va
    Quote Originally Posted by Sir William View Post
    Antique malls are probably your best source for shirt studs. Since you are unhappy with the traditional gold studs, you might want to look for a set of "black" mother-of-pearl studs (actually they are made from abalone shell) which will look very elegant on your white shirt front. Expect to pay about $25 for a good set of 1/4-inch studs, perhaps a bit more with matching cuff links.
  1. Etiquette Help
    By KenB in forum Kilt Advice
    Last Post: 19th January 10, 08:29 PM
  2. Kilt Etiquette
    By Andy in forum General Kilt Talk
    Last Post: 19th April 09, 05:21 AM
  3. Etiquette
    By Southern Breeze in forum Miscellaneous Forum
    Last Post: 14th February 09, 11:23 AM
