Results 1 to 7 of 7
    14th March 12
    Risingsun Ohio, USA
    Feeling like trying another experement.
    This could be an expensive experiment, so I'm asking for some thoughts and opinions before I get started. I'm thinking about commissioning a Montrose doublet. The thing that makes it experimental is that I was considering having it made in either a medium grey worsted wool or maybe even twill, with antiqued brass round dome buttons. The idea is to get a more dressed down version than what is commonly available. So does anyone have any thoughts before I start talking to my seamstress?
    Keep your rings charged, pleats in the back, and stay geeky!
    https://kiltedlantern.wixsite.com/kiltedlantern
  2. The Following User Says 'Aye' to Sir Didymous For This Useful Post:
    19th October 09
    South Queensferry, Scotland
    Two immediate thoughts Sir Didymous: temperature and formality.
    Most doublets can be worn open if the temperature is high, the Montrose needs to be buttoned up. There is a double of layer of fabric across the chest and it is normally very close fitting (figure hugging). In modern centrally-heated venues, it can be insufferably hot.
    Since the Montrose needs to be worn with a lace jabot or cravat, which are very dressy, it is a difficult doublet to dress down.
    Having said this, I did once see one worn open at the top with a black bow tie, the flaps buttoned back to form collars, and it didn't look too bad but still very formal.
    IMHO there are more appropriate doublet and jacket styles that would look good in the fabrics and buttons you suggest,
    It's coming yet for a' that,
    19th October 09
    South Carolina
    There are worsted ones ( as opposed to velvet) around. If you just want to dip your toe in, consider a USAF academy cadet jacket, which is very close to what you are looking for. Here is one that will be perfect, if you wear a size 36 coat: http://www.ebay.com/itm/U-S-AIR-FORC...item565ba8ab71
    You may also like to try this pattern from Folkwear http://www.folkwear.com/133.html
    The buttons aren't as widely spaced as some, but they give good advice about contrasting facings, etc., and your tailor might be able to stretch the spacing...
    Another good one is McCall's Pattern 4745. Just stop it at the waist.
  5. The Following User Says 'Aye' to MacLowlife For This Useful Post:
  6. #4
    19th October 09
    South Carolina
    speaking of the montrose...
    And assuming you are not in the 38-40 size department yourself, Sir D, Here is a nice one available ready made at an attractive price...
    http://www.ebay.com/itm/Mens-montros...item2a342b5816
    I am not sure about the Saltire ornaments on the back- maybe someone else can explain them.
  7. #5
    14th March 12
    Risingsun Ohio, USA
    Thanks MacLowlife, but I am in a considerably larger size than either of these (48). It is however funny that you should mention the McCalls pattern; that is what I am using as a base design when I sit down with the seamstress. I saw one of my buddies that reenacts the American Civil War as a confederate officer. They frequently fold the top flaps back much like MacRobert's Reply was talking about. I think that with the right shirt and tie style, it could be dressed down a bit. Granted, there are doublet styles that better lend themselves to dressing down, but I figure the worst case scenario is that I get a formal doublet. I could use one anyhow. Having said that though, I think that the combination of a more toned down material and dull buttons will aid in this attempt.
  8. #6
    20th December 10
    Maine
    If you don't care for the McCall pattern try the one from Folkwear Sewing patterns #133 "Belgan Military Chef Jacket" It is a short double breasted upturned collar pattern.
  9. The Following User Says 'Aye' to tky58 For This Useful Post:
  10. #7
    20th December 10
    Maine
    BTW they have a kilt pattern also.
