6th March 06, 05:28 PM
Picking out the pleat thread?
Not sure what the technical term is but you know that thread that holds down the pleats on a kilt when it's off the rack and being mailed to you? What's the most effective way that you've found to remove it safely without destroying or damaging the kilt. I thought I was doing a good job on the new solid black kilt I got until I saw where I trimmed a small part of the kilt in addition to the string. Nothing major or noticeable which is but I wanted to know what methods others have found to work in removing that pesky thread....
6th March 06, 06:23 PM
That is the basting thread, Brian. There is no 'correct' way of dealing with them - I use fine-pointed nail scissors (or a dressmaker's thread-ripper when I can find it!!) and carefully snip the thread at about every third pleat, taking my time. These things should not be rushed. Having done that, the pieces of thread can easily be pulled out, pulling gently sideways NOT upwards. Beware though of any knots and make sure you do not try to pull those through the fabric.
If you snipped the fabric, I imagine you were in too much of a hurry to set those pleats free. "Take it nice and easy - every time". Boohm! Boohm!
6th March 06, 06:50 PM
I use a letter opener. No way to cut anything except the thread.
David
6th March 06, 06:54 PM
I use a small pair of pointy scissors. Like Ham, I snip the thread about every 3rd pleat, then carefully pull the pieces out.
6th March 06, 07:01 PM
I actually used a pair of nail clippers to get rid of the basting thread and picked up some of the fabric as well. It puckered a bit but nothing overly major...Thanks for the tip and I'll remember that next time I get a kilt done that way.....
6th March 06, 07:50 PM
That's my method as well.
6th March 06, 08:26 PM
A seam ripper is the best way. It is small, pointed, and not prone to cutting anything other than what you are aiming at.
6th March 06, 08:33 PM
and you can pick one up at just about any drug store or grocery. just have to be careful where you leave it as that can be rather painful to sit on!!!
ITS A KILT, G** D*** IT!
WARNING: I RUN WITH SCISSORS
“I asked Mom if I was a gifted child… she said they certainly wouldn’t have paid for me."
6th March 06, 09:26 PM
You're supposed to take those things off??
Just kidding.
6th March 06, 10:15 PM
Sorta along the same lines...new kilts seem to always have loose threads sticking out of seams. I use one of those long tube candle lighters to burn them back. Depending on the thread type you gotta pay attention, but its fast and easy and seems to help hold the thread in place. Kilt looks a lot sharper too.
Ron
